[GRASS-user] r.massmov
Massimiliano Cannata massimiliano.cannata at supsi.ch
Fri Jan 30 14:45:49 PST 2015
Danilo,
While developing we used Ubuntu and it was grass 7.0
Maxi
Il giorno mer 28 gen 2015 15:42 DEBERNARDI DANILO <
d.debernardi4 at studenti.uninsubria.it> ha scritto:
> I think that the quickest solution for this problem could be to change my
> pc platform or use a virtual platform (virtual box)
> Could it be ?
> What platform does support the r.massmov addon without error or interface
> problem?
> Thanks, for the patience
> ________________________________________
> Da: grass-user-bounces at lists.osgeo.org <grass-user-bounces at lists.osgeo.org>
> per conto di Helmut Kudrnovsky <hellik at web.de>
> Inviato: sabato 24 gennaio 2015 15.17
> A: grass-user at lists.osgeo.org
> Oggetto: Re: [GRASS-user] r.massmov
> > It means that there's something to fix in the module?  Or is a grass
> issue?
> tested here again:
> GRASS Version: 7.1.svn
> GRASS SVN revision: 64291
> Build date: 2015-01-24
> Build platform: i686-pc-mingw32
> GDAL: 1.11.1
> PROJ.4: 4.8.0
> GEOS: 3.4.2
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
> Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
> as r.massmov doesn't show any (re)action, it's hard to say; but I assume a
> fix in r.massmov is needed.
> a quick test with different debug levels:
> g.gisenv set=DEBUG=3
> g.gisenv set=DEBUG=5
> C:\>r.massmov
> C:\>
> C:\>r.massmov --help
> C:\>
> C:\>r.massmov --ui
> C:\>
> if you try to invoke the module, unfortunately nothing happens: no error
> message, no debug message, ...
> maybe something with parallelization in windows?
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/r-massmov-tp5181466p5183520.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150130/052801f8/attachment.html>
