[GRASS-user] GRASS 7.0.0 Issues with Object Based Image Analysis
Vaclav Petras wenzeslaus at gmail.com
Thu May 14 13:23:50 PDT 2015
On Thu, May 14, 2015 at 2:00 PM, Jake Chila <jake.chila at gmail.com> wrote:
> The first issue I ran into was trying to the python code (about halfway
down the page, "for maps in MAPS"). I have changed the parameters so they
suit GRASS 7.0 but I still receive this error:
> Traceback (most recent call last):
>   File "C:\Users\Jacob\Desktop\Python\SEG_DB_MAN.py", line 111, in
<module>
>     column_prefix='%s' % bnum)
>   File "C:\Program Files (x86)\GRASS GIS
7.0.0\etc\python\grass\script\core.py", line 375, in run_command
>     return handle_errors(returncode, returncode, args, kwargs)
7.0.0\etc\python\grass\script\core.py", line 310, in handle_errors
>     returncode=returncode)
> CalledModuleError: Module run None ['v.rast.stats', '-c',
'map=LE7_2001_SEG', 'column_prefix=B1', 'method=median',
'raster=LE7_ATCORR_2001_B1'] ended with error
> Process ended with non-zero return code 1. See errors in the (error)
output.
Hi, are there any other errors above or elsewhere the output? The actual
error messages start with "ERROR:". (I guess I should add this note to the
error message.) Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150514/70fd652a/attachment.html>
