[GRASS-user] river and dams in netwok analysis
Etienne DELAY etienne.delay at etu.unilim.fr
Mon Oct 26 07:15:32 PDT 2015
Dear all dear Markus,
Above all great job GRASS dev team ! Grass 7 is so nice and powerful.
I'm always in the dark with my dams problem.
I would like to export dams points as node and for each node in the
attribute table 2 new column : dam before | dam after. I'm looking for
network analysis but it may be a wrong way ?
There is a way to do that in Grass?
Cordialement
Etienne DELAY (Skype : etienne.delay.tic)
Chaire: Capital environnemental et gestion durable des cours d'eau
laboratoire GEOLAB UMR 6042 CNRS
Université de Limoges, FLSH
39E rue Camille Guérin 87036 Limoges
blog : http://elcep.legtux.org
Le 18/10/2015 17:30, Markus Neteler a écrit :
> On Sat, Oct 17, 2015 at 11:17 AM, Etienne DELAY
> <etienne.delay at etu.unilim.fr <mailto:etienne.delay at etu.unilim.fr>> wrote:
>  > Re,
>  > I have read carefully the v.out.ogr as will said for tring to export the
>  > network layer but I've got an error :
>  > v.out.ogr --overwrite input=network at PERMANENT type=point dsn=~/ layer=2
>  > format=ESRI_Shapefile
>  > WARNING: 111738 line(s) found, but not requested to be exported. Verify
>  >          'type' parameter.
> (I guess that you need to set "type=line" and not "type=point")
> ... this is why you may consider to upgrade to the current 7.0.x stable
> version. Note the differences:
> https://grass.osgeo.org/grass64/manuals/v.out.ogr.html
> type=string[,string,...] Feature type(s).
>    Combinations not supported by all output formats. Default: first type
> found in input.
>    Options: point,line,boundary,centroid,area,face,kernel,auto
>    Default: line,boundary
> https://grass.osgeo.org/grass70/manuals/v.out.ogr.html
>    Combination of types is not supported by all output formats.
>    Default is to use first type found in input vector map.
>    Options: point, line, boundary, centroid, area, face, kernel, auto
>    Default: auto  <<==
> Less to think about, much faster vector data processing, improved
> network analysis along with new graphical frontend:
> https://grasswiki.osgeo.org/wiki/Vector_network_analysis#Screenshots
> Best
> Markus
