[GRASS-user] r.terraflow crashes
Vaclav Petras wenzeslaus at gmail.com
Mon Jan 4 07:18:09 PST 2016
On Mon, Jan 4, 2016 at 8:51 AM, Ken Mankoff <mankoff at gmail.com> wrote:
> I've figured out the issue, which is that I was looking at files on disk
> for some reason. I assume I shouldn't actually be in the
> /path/to/PERMANENT/ folder and use the x.info commands instead. Anyway,
> phi in the cell folder is 0 because it is a float, and the file does exist
> in the fcell folder.
Yes, the file in cell dir is there for each raster. And yes, r.info is the
right thing. GRASS Database, Location and Mapset are database, so special
tools like r.info are required.
> P.S. I'm using grass in Emacs Org-Mode. I find it a nice setup. There is
> no feedback (that is an Org limitation), but it is really nice to be able
> to write reproducible documents and interleave text/comments/manuscript
> with the GIS commands.
Interesting. Do you plan any blog post about it?
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160104/52d60cc0/attachment.html>
