[GRASS-user] Newbie questions about GRASS data model details
Uwe Fischer gisfisch at t-online.de
Thu Mar 17 12:14:26 PDT 2016
Hello all,
I'm quite new to GRASS (coming from ESRI and MicroStation) and have two
questions concerning the vector data model. I've read GRASS Wikis, manuals
and other docs from the web, but I could not find comprehensive answers yet.
Sorry for the long text ... :-)
First question: how are the different type determinations for geometry
objects saved in GRASS? What makes a boundary a boundary and separates it
from a line? The same for points and centroids.
I've read about the theoretical differences (eg., boundaries are split at
intersections and they make up closed rings). But those criteria can apply
to lines as well.
Command v.type is able to convert those types of geometry objects. That is,
lines can be converted to boundaries and vice versa. But how does the system
determine if an object is a line or a boundary? Where is that property
saved? Is there an invisible attribute column or flag that contains the
information? And how and when is that determination changed (if not by
v.type)?
Eg. when importing linestrings from DXF to GRASS with import option set to
"centroid, boundary", the importer will produce lines as well (it will do
this where linestrings have dangling errors). That means that there must be
an automated way (running in the background) of determining the geometry
type. What are the rules it follows?? As you can see, it does not do what
the user chooses in the import options that were set. If that was the case,
no lines would come out, just boundaries.
Second: Up to now, I was not able to understand the concept of layers in
GRASS. I've read a lot of explanations, most of them telling that a layer is
a set of category values making up a different view to the underlying
geometry objects. Using layers, the geometries can be aggregated or
individually marked in a different, yet parallel manner at the same time.
But everything described in the manual or Wiki seems to me like one can do
this using different attribute columns as well. IMHO, that applies even to
the Wiki example that was just produced to show the advantage of the layer
concept over attribute columns (example with field borders that are paths at
the same time).
So question Nr. 2 is: what is the real advantage of the layer concept over a
sophisticated set of attribute columns? And where is that layer structure
saved physically? Can I make it visible? In the end, is it just a set of
(most of the time invisible) columns??
Thanks and regards, Uwe
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160317/72de02a6/attachment.html>
