[GRASS-user] Newbie questions about GRASS data model details
Helmut Kudrnovsky hellik at web.de
Thu Mar 17 13:29:24 PDT 2016
some of my naive understanding of the data model:
>First question: how are the different type determinations for geometry
objects saved in GRASS? What >makes a boundary a boundary and separates it
from a line? The same for points and centroids.
taken from https://grass.osgeo.org/grass70/manuals/vectorintro.html
- point: a point;
- line: a directed sequence of connected vertices with two endpoints called
nodes;
- boundary: the border line to describe an area;
- centroid: a point within a closed ring of boundaries;
- area: the topological composition of a closed ring of boundaries and a
centroid;
an area is build upon boundaries and centroid; e.g. change line to
boundaries and point to centroid and build and area
>Second: Up to now, I was not able to understand the concept of layers in
GRASS. I've read a lot of >explanations, most of them telling that a layer
is a set of category values making up a different view to >the underlying
geometry objects. Using layers, the geometries can be aggregated or
individually marked in >a different, yet parallel manner at the same time.
>But everything described in the manual or Wiki seems to me like one can do
this using different attribute >columns as well.
just think of a line representing a road: e.g. layer 1 represents the road
type (e.g. small road ... highway), layer 2 holds the information if it's
allowed for bicycles; with the layer concept you doesn't need an attribute
table (but you can have also attribute tables in every layer) to hold
different characteristics of e.g. a line, boundary, point etc.
but obviously there is some overlapping between the layer and/or attribute
concept...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Newbie-questions-about-GRASS-data-model-details-tp5257044p5257056.html
Sent from the Grass - Users mailing list archive at Nabble.com.
