[GRASS-user] measure distance on d.mon without g.gui?
Tyler Smith tyler at plantarum.ca
Fri Mar 18 10:59:27 PDT 2016
On Fri, Mar 18, 2016, at 12:57 PM, Vaclav Petras wrote:
> With d.mon the things written to the Command Console tab in main GUI
> (g.gui) are written to the stdout, i.e. they should be visible in your
> command line. This was not possible in 6.4 with wxGUI but it is
> possible with version 7.
This works from a terminal (i.e., xterm), but it doesn't seem to work
from within Emacs (using GRASS-mode, which is built on shell-mode/comint-
mode). Which means it's my fault! Strange, though, as other STDOUT text
comes through just fine. I do get a `^G` symbol where the distance
should appear, suggesting GRASS is sending a 'BELL' symbol, which may be
confusing Emacs. I'll have to look into this.
Thanks,
Tyler
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160318/e8d3d567/attachment-0001.html>
