[GRASS-user] i.segment.stats memory usage error
Moritz Lennert mlennert at club.worldonline.be
Mon Nov 7 06:13:38 PST 2016
Hi James,
On 04/11/16 22:08, James Duffy wrote:
> Sorry to post again on this long thread...
No worries :-)
> I have just managed to get my hands on a 64bit osgeolive install with
> 12GB RAM available and the afformentioned function worked. Just to
> reiterate this was i.segment.stats on gp_seg_optimum_clump (which was
> the output of i.segment, run through r.clump). I haven't created the
> vectormap, but it seems that the csv was created correctly.
> I don't know if it was the 64bit or the bit of extra RAM that made the
> difference here.
I would guess the extra RAM, but am no expert on these questions.
I'm working on a revised version of i.segment.stats to use
r.stats.quantile. It would be great if you could test that once its done.
Moritz
> James
> On 4 November 2016 at 15:34, Markus Metz <markus.metz.giswork at gmail.com
> <mailto:markus.metz.giswork at gmail.com>> wrote:
>     On Fri, Nov 4, 2016 at 3:51 PM, Moritz Lennert
>     <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>     wrote:
>     > On 04/11/16 14:29, Markus Metz wrote:
>     >> On Wed, Nov 2, 2016 at 5:15 PM, Markus Metz
>     >>> On Wed, Nov 2, 2016 at 3:47 PM, Moritz Lennert
>     <mailto:mlennert at club.worldonline.be>> wrote:
>     >>>> On 02/11/16 11:05, James Duffy wrote:
>     >>>>> I can't register with osgeo to submit a bug as no-one has
>     replied with
>     >>>>> a
>     >>>>> 'mantra' for me to do so... what a convoluted bug reporting
>     system!
>     >>>>> And in your opinion Moritz, does it look like my workflow will
>     not be
>     >>>>> possible unless I find a 64bit machine with a decent amount of
>     RAM?
>     >>>> I'm not sure about the necessity of 64bit, but more RAM probably.
>     >>>> IIUC, all the stats of all the zones are put into memory during
>     the run
>     >>>> of
>     >>>> the module. Maybe a file-based store of the information might be
>     >>>> possible
>     >>>> which would avoid this memory usage, but I'm not sure.
>     >>>> @MarkusM: could you have a look at this ? See
>     https://lists.osgeo.org/pipermail/grass-user/2016-October/075493.html <https://lists.osgeo.org/pipermail/grass-user/2016-October/075493.html>
>     >>>> for
>     >>>> the beginning of the thread. In short: James seems to be
>     hitting memory
>     >>>> limits of r.univar and I'm wondering out loud whether there is
>     something
>     >>>> that could be done about this...
>     >>> As Anna wrote, the -e flag increases memory consumption of r.univar
>     >>> considerably. A file based approach for extended stats of
>     r.univar is
>     >>> difficult because the number of values per segment is initially
>     >>> unknown to r.univar, thus the amount of disk space needed for
>     extended
>     >>> stats for each segment is unknown.
>     >>> I would rather use r.univar for standard stats and r.stats.quantile
>     >>> for extended stats.
>     >> There were some bugs in r.stats.quantile, fixed in r69770-2 in all G7
>     >> branches.
>     > Great, thanks !
>     >> About the limit to MAX_CATS categories in the base map (ticket
>     #3198),
>     >> there is not really a reason for it. I guess it is meant to protect
>     >> against out-of-memory errors.
>     > Does this mean we can just take out the lines referencing it ?
>     Maybe replace the error with a warning. I tested with a base map with
>     1.4 million categories (output of i.segment) and it works, but I
>     needed to reduce the number of bins from 1000 to 100 to avoid OOM.
>     With a low number of bins, the memory consumption of r.stats.quantile
>     is much less than what r.univar requires, but a low number of bins can
>     in some cases (histogram of the cell values with a peak) lead to
>     higher memory consumption.
>     r.univar does memory reallocation on demand which means that for a
>     short time, double the amount of memory is needed. r.univar2 makes a
>     guess about how much memory is required and then allocates all at
>     once. Still, the binning approach of r.(stats.)quantile usually needs
>     less memory.
>     Markus M
