[GRASS-user] Importing data in .atx/.gdb format
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Wed Sep 14 00:24:06 PDT 2016
Hei Rich,
Regarding the v.in.ogr command, I was a bit unclear (with folder I meant the "FGDB object" whit the .gdb ending, which the OS treats a folder)
For me:
v.in.ogr -l input=D:\Geodatabases\Topographic_data_2014.gdb
works without issues.
As Helmut wrote, if that does not work you should check if your GDAL installation supports FGDB:
ogrinfo --formats
Kind regards,
Stefan
-----Original Message-----
From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Helmut Kudrnovsky
Sent: 14. september 2016 07:25
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Importing data in .atx/.gdb format
Rich Shepard wrote
> On Tue, 13 Sep 2016, Blumentrath, Stefan wrote:
>> Thus, you should be able to import your transport data (assuming it
>> is
>> vector) with v.in.ogr. A FGDB is as you say also a folder, but if I
>> am not mistaken you do not have to provide special files to OGR:
>> v.in.ogr input=your_FGDB_folder layer=the_relevant_layer
>> output=your_output
> Stefan,
>    This almost works -- using the GUI. I've no idea which file
> represnts the relevant layer.
>    Selecting File -> Import vector (v.in.ogr) opens the dialog box.
> There, I change the source type radiobox choice from File to
> Directory, use the dropdown choice list for Source list format to
> OpenFileGDB, and select the Directory as ~/data/grassdata/ODOT2014.
>    The bottom checkbox of options doesn't matter because when I click
> the Import button a message box displays reading, "No layers selected.
> Operation
> canceled." That's because all layers were greyed out when I selected
> that directory.
>    When I try specifing source type as File grass does not like my
> selecting a filename with 'index' in the extension.
>> A list of available layers should be accessible like this:
>> v.in.ogr input=your_FGDB_folder -l
>> v.in.ogr input=~/data/grassdata/ODOT2014 -l
> ERROR: Unable to open data source
> </home/rshepard/data/grassdata/ODOT2014>
> Thanks,
> Rich
> grass-user mailing list
> grass-user at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-user
As mentioned in an earlier reply before, GRASS GIS uses for import gdal /ogr.
so have a look at www.gdal.org and check the 2 drivers for this filegdb format how gdal /ogr handles this format.
The next step may be :
- ogrinfo your_filegdb_folder to see if your gdal /ogr installation is capable to read this kind of data and if yes, to see which layer(s) are inside this data
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Importing-data-in-atx-gdb-format-tp5285623p5285714.html
Sent from the Grass - Users mailing list archive at Nabble.com.
