[GRASS-user] 7.3.svn observations
Rich Shepard rshepard at appl-ecosys.com
Wed Sep 28 07:31:45 PDT 2016
On Wed, 28 Sep 2016, Anna Petrášová wrote:
> Not wrong, you used 'input' parameter which accepts file. In GUI you can
> type into the field right away and it automatically creates a temporary
> file. But if you don't save this file, it will be deleted. The saved gxw
> file will have saved the path to temp file, which is the problem.
> The behavior is the same for 7.2 and 7.3.
Anna,
   OK. I'll try again.
Thanks,
Rich
