[GRASS-user] [Process ended with error code -1073741515]
Ang Sherpa angsherpa232 at gmail.com
Tue Mar 21 02:57:30 PDT 2017
Module import into python script is working fine. However, when I tried to
print out the g.region with
gscript.run_command('g.region',raster='nep_drain',overwrite=True). It
throws the following error.
Process ended with non-zero return code -1073741515
Any words would be appreciated.
*Best,*
*Ang Dawa Sherpa*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170321/b26174e3/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170321/b26174e3/attachment.png>
