[GRASS-user] [Process ended with error code -1073741515]
Helmut Kudrnovsky hellik at web.de
Tue Mar 21 03:30:41 PDT 2017
Ang Sherpa wrote
> Module import into python script is working fine. However, when I tried to
> print out the g.region with
> gscript.run_command('g.region',raster='nep_drain',overwrite=True). It
> throws the following error.
> Process ended with non-zero return code -1073741515
> Any words would be appreciated.
> *Best,*
> *Ang Dawa Sherpa*
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user
> xenia_error.png (24K)
> <http://osgeo-org.1560.x6.nabble.com/attachment/5313360/0/xenia_error.png>
have a look in this thread:
https://lists.osgeo.org/pipermail/grass-user/2016-August/074634.html
grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n'] ended
with error
Process ended with non-zero return code -1073741515. See errors in the
(error) output.
and here
http://stackoverflow.com/questions/1081276/where-can-i-find-a-list-of-all-windows-error-codes
to find the meaning of the error code in
https://msdn.microsoft.com/de-de/library/windows/desktop/ms681381(v=vs.85).aspx
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Process-ended-with-error-code-1073741515-tp5313360p5313370.html
Sent from the Grass - Users mailing list archive at Nabble.com.
