[GRASS-user] Importing lat-lon points into projected location
Rich Shepard rshepard at appl-ecosys.com
Tue Jul 3 05:39:13 PDT 2018
On Tue, 3 Jul 2018, Nikos Alexandris wrote:
> The points are there. Matching the computational/visible region to a
> vector, is as exact as it can be. The default point symbol, 'basic/x',
> sits for the two "extreme" points on the corners of the visible region.
> The default size for the 'x' point symbol is, likely, too small. Try with
> a "better" background and size.
Nikos,
   I suspected the points were correctly located while the attribute table
retained the lat-lon values, but that needed verification.
   It did not occur to me to change the region to that one map to look more
closely at the points.
> Using your points above,
   Thanks for the process.
Regards,
Rich
