[GRASS-user] Importing lat-lon points into projected location
Rich Shepard rshepard at appl-ecosys.com
Tue Jul 3 15:03:20 PDT 2018
On Wed, 4 Jul 2018, Micha Silver wrote:
> Your coordinates are in long/lat so when using v.in ascii you *must*
> import into a long/lat based location. Then change to your other projected
> location and do v.proj to reproject from long/lat to the projected
> location.
Micha,
   It's been so long since I worked with long/lat data I could not find old
references on how to define a non-projected, long/lat location. I thought
the answer might be found on the wxGUI new location creation wizard but
didn't see it there as an option.
> BTW, EPSG 3828 seems to be a CRS used in Taiwan. Is that what you want?
   Nope. I mis-remembered. It's EPSG 2838; same digits, different order.
Toda,
Rich
