[GRASS-user] Spyder IDE with GRASS
Bernardo Santos bernardo_brandaum at yahoo.com.br
Fri Jun 1 12:13:47 PDT 2018
 Hi Alex,
I have no sollutions, but I am also interested on that, if someone has hints...
Bernardo
    Em sexta-feira, 1 de junho de 2018 14:35:27 BRT, Moody, Alex <Alex.Moody at idwr.idaho.gov> escreveu:
  <!--#yiv7338937435 _filtered #yiv7338937435 {font-family:"Cambria Math";panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv7338937435 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}#yiv7338937435 #yiv7338937435 p.yiv7338937435MsoNormal, #yiv7338937435 li.yiv7338937435MsoNormal, #yiv7338937435 div.yiv7338937435MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", sans-serif;}#yiv7338937435 a:link, #yiv7338937435 span.yiv7338937435MsoHyperlink {color:#0563C1;text-decoration:underline;}#yiv7338937435 a:visited, #yiv7338937435 span.yiv7338937435MsoHyperlinkFollowed {color:#954F72;text-decoration:underline;}#yiv7338937435 p.yiv7338937435MsoListParagraph, #yiv7338937435 li.yiv7338937435MsoListParagraph, #yiv7338937435 div.yiv7338937435MsoListParagraph {margin-top:0in;margin-right:0in;margin-bottom:0in;margin-left:.5in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", sans-serif;}#yiv7338937435 span.yiv7338937435EmailStyle17 {font-family:"Calibri", sans-serif;color:windowtext;}#yiv7338937435 .yiv7338937435MsoChpDefault {font-family:"Calibri", sans-serif;} _filtered #yiv7338937435 {margin:1.0in 1.0in 1.0in 1.0in;}#yiv7338937435 div.yiv7338937435WordSection1 {}#yiv7338937435 _filtered #yiv7338937435 {} _filtered #yiv7338937435 {} _filtered #yiv7338937435 {} _filtered #yiv7338937435 {} _filtered #yiv7338937435 {} _filtered #yiv7338937435 {} _filtered #yiv7338937435 {} _filtered #yiv7338937435 {} _filtered #yiv7338937435 {} _filtered #yiv7338937435 {}#yiv7338937435 ol {margin-bottom:0in;}#yiv7338937435 ul {margin-bottom:0in;}-->
I occasionally try to use GRASS via the Spyder IDE but have not found a solution that works so far. I am working in Windows 7 with various versions of GRASS (72, 74, 75) through the OSGEO install. My attempts include
1.      Manually installing Spyder into the OSGEO python site-packages directory. When I run spyder after launching a GRASS session or from the OSGEO shell, nothing happens. I’ve seen the Wiki page discussing Spyder that mentions the commandspyder –w . 2>dev/null &, though I am not sure what this is attempting to do
2.      Making a conda environment and using subprocess per the Wiki. I imagine this fails because GRASS isn’t install in this environment. I wonder if there is a way to set the environment to use the GRASS python executable?
Has anyone had success using Spyder that could offer some further pointers?
Thanks,
Alex
grass-user mailing list
grass-user at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180601/6bc242d9/attachment.html>
