[GRASS-user] v.clean: recommend tools and sequence
Rich Shepard rshepard at appl-ecosys.com
Fri Jun 29 09:32:44 PDT 2018
On Fri, 29 Jun 2018, Markus Metz wrote:
> After import with v.in.ogr, overlapping parts have a category value set in
> layer 2. If you want to get rid off all overlapping parts, check with
> v.category op=report if any centroids still have a category value in layer
> 2. Sometimes these areas can be cleaned away with v.clean tool=rmarea,
> sometimes manual editing with the vector digitizer is needed.
Markus,
   Followed your advice and there are still the same warnings with the same
values. Is there a way for me to determine where in this large map of
publicly-owned forests in the state the 107 overlapping polygons are
located?
Regards,
Rich
