[GRASS-user] Possible Grass Bug
Rich Shepard rshepard at appl-ecosys.com
Sat Jun 30 16:04:33 PDT 2018
On Sun, 1 Jul 2018, ubuntu wrote:
> What is the difference between the console at the layer manager tab and
> the GRASS 7.4.0 (nc_spm_08_grass7):~ > at the ubuntu terminal? when should
> I use the console and when the other one? And what is the difference
> between wx0,1,2, ... windows and the Grass GIS Map Display window (the one
> that loads along with the layer manager)?
Nozhan,
   You will find that you have more control working at the console,
particularly when the wxGUI does not recognize files you want to use. The
GUI can be quite useful, but working at the console is preferred by those
who are used to working on consoles in linux, *BSD, and various unices.
Also, you can write scripts to perform repetative or complex processes and
run them from the command line. The GUI does not support this.
   Either on a 'getting started' or wiki page is a list of commands to start
grass. In your installation 'grass' and 'grass74' are synonymous. If you run
multiple versions (e.g., 7.4.x and 7.5svn) then you want to assign each to a
unique name.
Regards,
Rich
