[GRASS-user] V.Kriging
Francois Chartier fra.chartier at gmail.com
Fri Jan 18 05:12:37 PST 2019
i have not installed these libraries. i am not sure how to do this either.
On Fri, Jan 18, 2019, 01:33 Markus Neteler <neteler at osgeo.org wrote:
> Hi,
> On Fri, Jan 18, 2019 at 2:02 AM Francois Chartier
> <fra.chartier at gmail.com> wrote:
> > I tried to install v.kriging with g.extension and it does not work see
> error message.  i have been able to installed other
> > addon such as v.vol.idw, v.delaunay3d, and running them.
> > g.extension extension=v.kriging url=
> > WARNING: Extension <v.kriging> already installed. Re-installing...
> > Downloading precompiled GRASS Addons <v.kriging>...
> > Updating addons metadata file...
> > ERROR: Unable to read manual page: [Errno 2] No such file or directory:
> 'C:\\Users\\Francois
> Chartier\\AppData\\Roaming\\GRASS7\\addons\\docs\\html\\v.kriging.html'
> > (Thu Jan 17 19:53:56 2019) Command finished (2 sec)
> > the module is installed but when pressing run
> > Unable to fetch interface description for command
> > 'v.kriging'.
> > Details: Cannot find the executable v.kriging
> What I can see is some issue in the compile log on the wingrass server:
> https://grass.osgeo.org/grass74/manuals/addons/
> --> Windows log files
>     --> vector/v.kriging FAILED log
> http://wingrass.fsv.cvut.cz/grass74/x86/addons/latest/logs/v.kriging.log
> " #error GRASS GIS is not configured with BLAS (la.h cannot be included)
> This means that the LAPACK/BLAS numerical libraries are apparently not
> installed/activated on the wingrass server on which the WinGRASS
> addons are built.
> Maybe Martin has some insights here?
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190118/2d58f1e5/attachment.html>
