[GRASS-user] error importing rasters
Veronica Andreo veroandreo at gmail.com
Thu Mar 28 05:14:33 PDT 2019
Hi Alessandro,
did you import the rasters in a newer version of GRASS, i.e., 7.6? It seems
to me it is not recognizing the compression which is now by default in 7.6,
but not in 7.4. I would try to get 7.6 installed again.
For sure others know better
best,
Vero
El jue., 28 mar. 2019 a las 12:38, Alessandro Sebastiani (<
alessandro.sebastiani at uniroma1.it>) escribió:
> hello to everyone,
> when i try to import a raster (i tried more than one) i got the following
> error (in this case i was importing an ndvi raster):
> > Failed to run command 'd.rast map=ndvi_20180715 at alessandro'. Details:
> GRASS_INFO_WARNING(2682,1): Request for unsupported compressor
> GRASS_INFO_END(2682,1)
> GRASS_INFO_WARNING(2682,2): Request for unsupported compressor
> GRASS_INFO_END(2682,2)
> GRASS_INFO_ERROR(2682,3): Request for unsupported compressor
> GRASS_INFO_END(2682,3)
> Failed to run command 'd.rast map=imd_2016_32n at alessandro'. Details:
> GRASS_INFO_WARNING(2683,1): Request for unsupported compressor
> GRASS_INFO_END(2683,1)
> GRASS_INFO_WARNING(2683,2): Request for unsupported compressor
> GRASS_INFO_END(2683,2)
> GRASS_INFO_ERROR(2683,3): Request for unsupported compressor
> GRASS_INFO_END(2683,3)
> Failed to run command 'd.rast map=munpm10_average at alessandro'. Details:
> GRASS_INFO_WARNING(2684,1): Request for unsupported compressor
> GRASS_INFO_END(2684,1)
> GRASS_INFO_WARNING(2684,2): Request for unsupported compressor
> GRASS_INFO_END(2684,2)
> GRASS_INFO_ERROR(2684,3): Request for unsupported compressor
> GRASS_INFO_END(2684,3)
> i run GRASS on UBUNTU 18.04.2 and i reistalled it yesterday since i was
> having some troubles using GUI. I'm using version 7.4.0.
> does anyone know what's wrong??
> A.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190328/4bd9ca7a/attachment.html>
