[GRASS-user] Fwd: GRASS GIS problem from OSGeo4W Setup
Valter Albino valteralbino at gmail.com
Sun Feb 2 02:05:54 PST 2020
Hi Helmut,
Thanks for reply.
Feel embarrassed, since i can't find the file path you mention.
Tried to install again, but the error remains, starting in the installation:
[image: Capturar.GIF]
In my portable PC i did the same but didn't give error, so can run GRASS
GIS with no problems.
I didn't change the language
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Helmut Kudrnovsky <hellik  web.de> escreveu no dia domingo, 2/02/2020 à(s)
08:48:
> Valter Albino wrote
> > Regarding the issue, this message is also important (during instalation):
> > [image: ScreenHunter_31 Feb. 01 20.04.gif]
> > Cumprimentos,
> > ---------- Forwarded message ---------
> > De: Valter Albino <
> > valteralbino@
> > Date: sábado, 1/02/2020 à(s) 19:52
> > Subject: GRASS GIS problem from OSGeo4W Setup
> > To: grass-user <
> > grass-user  .osgeo
> > Hi
> > *1)* Trying to install GRASS 7.8.2 or 7.9.dev but have the following
> > message:
> > OSGeo4W Setup - Running postinstall scripts
> > Postinstall script errors
> > These do not necessarly mean that affectes packages will fail to function
> > properly, but please check /var/log/setup.log.full and report any
> > problems.
> > Package: Unknown package
> >     qgis-common.bat exit code -1073741511
> > *2)* So, when starting from windows menu, have the follwing message:
> > Starting GRASS GIS...
> > Error: Reading settings from file
> > <C:\Users\Particular\AppData\Roaming\GRASS7\wx> failed.
> >                 Details: not enough values to unpack (expected 2, got 1)
> >                 Line: ''
> > Using 64bits Windows OS, and having this issue from the 1st time, after
> > update QGIS and GRASS from OSGeo4W Setup.
> > Thanks
> > Cumprimentos,
> > grass-user mailing list
> > grass-user  .osgeo
> > https://lists.osgeo.org/mailman/listinfo/grass-user
> > ScreenHunter_31 Feb. 01 20.04.gif (15K)
> http://osgeo-org.1560.x6.nabble.com/attachment/5428909/0/ScreenHunter_31%20Feb.%2001%2020.04.gif&gt
> It's part of the OSGeo4W repackaging. Try to reinstall.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> grass-user  lists.osgeo.org
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200202/d825b5b0/attachment-0001.html>
Type: image/gif
Desc: não disponível
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200202/d825b5b0/attachment-0001.gif>
