[GRASS-user] Fwd: GRASS GIS problem from OSGeo4W Setup
Helmut Kudrnovsky hellik at web.de
Sun Feb 2 02:16:05 PST 2020
Valter Albino wrote
> Hi Helmut,
> Thanks for reply.
> Feel embarrassed, since i can't find the file path you mention.
> Tried to install again, but the error remains, starting in the
> installation:
> [image: Capturar.GIF]
> In my portable PC i did the same but didn't give error, so can run GRASS
> GIS with no problems.
> I didn't change the language
> Cumprimentos,
> *Valter Albino -* Geógrafo Físico, M.Sc.
> Modelação H&H / Riscos ambientais / OT&U
> www.valteralbino.wixsite.com/hydrodynamics
> Helmut Kudrnovsky <
> hellik@
> > escreveu no dia domingo, 2/02/2020 à(s)
> 08:48:
>> Valter Albino wrote
>> > Regarding the issue, this message is also important (during
>> instalation):
>> > [image: ScreenHunter_31 Feb. 01 20.04.gif]
>> > Cumprimentos,
>> > ---------- Forwarded message ---------
>> > De: Valter Albino <
>> > valteralbino@
>> > Date: sábado, 1/02/2020 à(s) 19:52
>> > Subject: GRASS GIS problem from OSGeo4W Setup
>> > To: grass-user <
>> > grass-user at .osgeo
>> > Hi
>> > *1)* Trying to install GRASS 7.8.2 or 7.9.dev but have the following
>> > message:
>> > OSGeo4W Setup - Running postinstall scripts
>> > Postinstall script errors
>> > These do not necessarly mean that affectes packages will fail to
>> function
>> > properly, but please check /var/log/setup.log.full and report any
>> > problems.
>> > Package: Unknown package
>> >     qgis-common.bat exit code -1073741511
>> > *2)* So, when starting from windows menu, have the follwing message:
>> > Starting GRASS GIS...
>> > Error: Reading settings from file
>> > <C:\Users\Particular\AppData\Roaming\GRASS7\wx> failed.
>> >                 Details: not enough values to unpack (expected 2, got
>> 1)
>> >                 Line: ''
>> > Using 64bits Windows OS, and having this issue from the 1st time, after
>> > update QGIS and GRASS from OSGeo4W Setup.
>> > Thanks
>> > Cumprimentos,
>> > _______________________________________________
>> > grass-user mailing list
>> > https://lists.osgeo.org/mailman/listinfo/grass-user
>> > ScreenHunter_31 Feb. 01 20.04.gif (15K)
>> http://osgeo-org.1560.x6.nabble.com/attachment/5428909/0/ScreenHunter_31%20Feb.%2001%2020.04.gif&gt
>> It's part of the OSGeo4W repackaging. Try to reinstall.
>> best regards
>> Helmut
>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> Capturar.GIF (140K)
> <http://osgeo-org.1560.x6.nabble.com/attachment/5428927/0/Capturar.GIF>
The path is something like
C:\users\yourusername\appdata\...\roaming\grass7
Do a search for grass7 in the appdata subfolder.
Or copy
 %APPDATA%
in the Windows file explorer to open directly the appdata folder.
best regards
Helmut
