[GRASS-user] Error importing 3d csv in grass
Helmut Kudrnovsky hellik at web.de
Sat May 7 23:12:24 PDT 2022
>v.in.ascii --overwrite
>input=/home/etorresm/Desktop/Vajont_Export_res_integer.csv
>output=voxel_res_int separator=comma skip=1 x=2 y=3 z=4 cat=5
>UNIQUE constraint failed: voxel_res_int.int_5
>DBMI-SQLite driver error:
>Error in sqlite3_step():
>ERROR: Unable to insert new record: insert into voxel_res_int values ( 2,
>1015614, 1048407, 2665, 4)
>WARNING: Table <voxel_res_int> linked to vector map <voxel_res_int> does
>not exist
can you share the 10 first lines of the input ascii file?
kind regards
Helmut
