[GRASS-user] Mouse coordinates in Map Window not following GUI settings projection
Eric Patton eric.r.patton at protonmail.com
Tue Aug 15 10:39:20 PDT 2023
I am having trouble getting the Grass GUI map window mouse coordinates to
display Lat-Long WGS84 coordinates in the lower-left corner of the display
window.
I checked the GUI settings Projection tab, and it is set to EPSG:4326,
and references /usr/local/share/proj/epsg, but I can't find this file anywhere
on my system.
Here are the closest matches:
cd /usr
find . -name "*epsg*"
./include/boost/geometry/srs/epsg.hpp
./include/boost/geometry/srs/projections/epsg_params.hpp
./include/boost/geometry/srs/projections/epsg.hpp
./include/boost/geometry/srs/projections/epsg_traits.hpp
./include/geotiff/epsg_datum.inc
./include/geotiff/epsg_proj.inc
./include/geotiff/epsg_gcs.inc
./include/geotiff/epsg_units.inc
./include/geotiff/epsg_ellipse.inc
./include/geotiff/epsg_vertcs.inc
./include/geotiff/epsg_pm.inc
./include/geotiff/epsg_pcs.inc
./local/gdal-3.7.1/data/epsg.wkt
./local/gdal-3.7.1/ogr/ogr_fromepsg.cpp
./local/gdal-3.7.1/swig/python/gdal-utils/osgeo_utils/samples/epsg_tr.py
./local/gdal-3.7.1/build/ogr/CMakeFiles/ogr.dir/ogr_fromepsg.cpp.o
./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_datum.inc
./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_proj.inc
./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_gcs.inc
./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_units.inc
./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_ellipse.inc
./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_vertcs.inc
./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_pm.inc
./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_pcs.inc
./local/lib/python3/dist-packages/osgeo_utils/samples/epsg_tr.py
./local/lib/python3/dist-packages/osgeo_utils/samples/__pycache__/epsg_tr.cpython-38.pyc
./local/share/gdal/epsg.wkt
Here's my system: (Linux Mint 20.3)
g.version -gre
version=8.3.dev
date=2023
revision=b3ba6c290d
build_date=2023-08-14
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
libgis_revision=a82501dc85
libgis_date=2023-02-27T12:45:25+00:00
proj=8.2.0
gdal=3.7.1
geos=3.12.0
sqlite=3.31.1
My proj installation was installed by Synaptic package manager, in the standard
places, /usr/bin and /usr/share/proj.
Thanks for any helps,
~ Eric.
