[GRASS-user] Mouse coordinates in Map Window not following GUI settings projection
Anna Petrášová kratochanna at gmail.com
Tue Aug 15 12:11:40 PDT 2023
On Tue, Aug 15, 2023 at 1:39 PM Eric Patton via grass-user <
grass-user at lists.osgeo.org> wrote:
> I am having trouble getting the Grass GUI map window mouse coordinates to
> display Lat-Long WGS84 coordinates in the lower-left corner of the display
> window.
> I checked the GUI settings Projection tab, and it is set to EPSG:4326,
> and references /usr/local/share/proj/epsg, but I can't find this file
> anywhere
> on my system.
I have there /usr/share/proj/epsg
but even if you can't find it, entering 4326 and proj string
+proj=longlat +datum=WGS84 +no_defs +type=crs
should do it. Then, you have to switch that on in map display settings (see
map display toolbar) -> Status bar -> Display coordinates in different CRS
The idea was to move the epsg panel in GUI settings to the map display
settings, but this part never got finished...
> Here are the closest matches:
> cd /usr
> find . -name "*epsg*"
> ./include/boost/geometry/srs/epsg.hpp
> ./include/boost/geometry/srs/projections/epsg_params.hpp
> ./include/boost/geometry/srs/projections/epsg.hpp
> ./include/boost/geometry/srs/projections/epsg_traits.hpp
> ./include/geotiff/epsg_datum.inc
> ./include/geotiff/epsg_proj.inc
> ./include/geotiff/epsg_gcs.inc
> ./include/geotiff/epsg_units.inc
> ./include/geotiff/epsg_ellipse.inc
> ./include/geotiff/epsg_vertcs.inc
> ./include/geotiff/epsg_pm.inc
> ./include/geotiff/epsg_pcs.inc
> ./local/gdal-3.7.1/data/epsg.wkt
> ./local/gdal-3.7.1/ogr/ogr_fromepsg.cpp
> ./local/gdal-3.7.1/swig/python/gdal-utils/osgeo_utils/samples/epsg_tr.py
> ./local/gdal-3.7.1/build/ogr/CMakeFiles/ogr.dir/ogr_fromepsg.cpp.o
> ./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_datum.inc
> ./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_proj.inc
> ./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_gcs.inc
> ./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_units.inc
> ./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_ellipse.inc
> ./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_vertcs.inc
> ./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_pm.inc
> ./local/gdal-3.7.1/frmts/gtiff/libgeotiff/epsg_pcs.inc
> ./local/lib/python3/dist-packages/osgeo_utils/samples/epsg_tr.py
> ./local/lib/python3/dist-packages/osgeo_utils/samples/__pycache__/epsg_tr.cpython-38.pyc
> ./local/share/gdal/epsg.wkt
> Here's my system: (Linux Mint 20.3)
> g.version -gre
> version=8.3.dev
> date=2023
> revision=b3ba6c290d
> build_date=2023-08-14
> build_platform=x86_64-pc-linux-gnu
> build_off_t_size=8
> libgis_revision=a82501dc85
> libgis_date=2023-02-27T12:45:25+00:00
> proj=8.2.0
> gdal=3.7.1
> geos=3.12.0
> sqlite=3.31.1
> My proj installation was installed by Synaptic package manager, in the
> standard
> places, /usr/bin and /usr/share/proj.
> Thanks for any helps,
> ~ Eric.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230815/eea47081/attachment.htm>
