[GRASS-user] Instructions for Linux Unbuntu install
Moffatt, Philip philip.moffatt at wsu.edu
Fri Aug 18 11:15:47 PDT 2023
Hi there - I have a linux box with the following version of Unbuntu:
Distributor ID: Ubuntu
Description:    Ubuntu 22.04.2 LTS
Release:        22.04
Codename:       jammy
A few weeks ago grass would start from the terminal and then my IT dept installed a program called "admin by request" and now the gui will not start. I get this error:
petbuser at PETB:~$ grass
Starting GRASS GIS...
Cleaning up temporary files...
          __________  ___   __________    _______________
         / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
        / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
       \____/_/ |_/_/  |_/____/____/   \____/___//____/
Welcome to GRASS GIS 8.2.2dev (3d37ee165c)
GRASS GIS homepage:                      https://grass.osgeo.org
This version running through:            Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
See citation options with:               g.version -x
If required, restart the GUI with:       g.gui wxpython
When ready to quit enter:                exit
Launching <wxpython> GUI in the background, please wait...
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
GRASS smrMFC/philip:~ > wxdigit.py: Could not load grass_vector.8.2.
wxnviz.py: Could not load grass_g3d.8.2.
g.findfile: error while loading shared libraries: libgdal.so.30: cannot open shared object file: No such file or directory
  File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
    lambda event: event.callable(*event.args, **event.kw) )
  File "/usr/local/grass82/gui/wxpython/wxgui.py", line 95, in show_main_gui
    mainframe = GMFrame(parent=None, id=wx.ID_ANY, workspace=self.workspaceFile)
  File "/usr/local/grass82/gui/wxpython/lmgr/frame.py", line 156, in __init__
    self.statusbar = SbMain(parent=self, giface=self._giface)
  File "/usr/local/grass82/gui/wxpython/lmgr/statusbar.py", line 38, in __init__
    self.mask = SbMask(self.widget, self.giface)
  File "/usr/local/grass82/gui/wxpython/lmgr/statusbar.py", line 87, in __init__
    self.Refresh()
  File "/usr/local/grass82/gui/wxpython/lmgr/statusbar.py", line 120, in Refresh
    if gs.find_file(
KeyError: 'name'
The IT department has now uninstalled the admin by request program by my issue persists. I wanted to try and reinstall grass, but I have not been able to get passed the PPA steps listed online. I do not know what to do next.
Thank you,
plm
From: grass-user <grass-user-bounces at lists.osgeo.org> on behalf of grass-user-request at lists.osgeo.org <grass-user-request at lists.osgeo.org>
Sent: Wednesday, August 16, 2023 12:00 PM
To: grass-user at lists.osgeo.org <grass-user at lists.osgeo.org>
Subject: grass-user Digest, Vol 208, Issue 16
[EXTERNAL EMAIL]
Send grass-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Furldefense.com%2Fv3%2F__https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-user__%3B!!JmPEgBY0HMszNaDT!pCOWNoUQztOHaiZEShGF2j8bqYxIW165dmf0v1mk36PlyrguZuVgkBvFT1KRtYD2mIW9Adki4s9VraI4iEVGD4nC0HoNlrAkjZk7KQ%24&data=05%7C01%7Cphilip.moffatt%40wsu.edu%7Ca372c25d2f0d49f4164b08db9e8b0b48%7Cb52be471f7f147b4a8790c799bb53db5%7C0%7C0%7C638278092265285702%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=7%2F7mqfEWOFR1G1ATL1ulfLL7n5NKjs%2F3Cm95bgD9%2FT4%3D&reserved=0<https://urldefense.com/v3/__https://lists.osgeo.org/mailman/listinfo/grass-user__;!!JmPEgBY0HMszNaDT!pCOWNoUQztOHaiZEShGF2j8bqYxIW165dmf0v1mk36PlyrguZuVgkBvFT1KRtYD2mIW9Adki4s9VraI4iEVGD4nC0HoNlrAkjZk7KQ$>
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        grass-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."
Today's Topics:
   1. Re: Mouse coordinates in Map Window not following GUI
      settings projection (Eric Patton)
Message: 1
Date: Wed, 16 Aug 2023 16:17:04 +0000
From: Eric Patton <eric.r.patton at protonmail.com>
To: Veronica Andreo <veroandreo at gmail.com>
Cc: Anna Petr??ov? <kratochanna at gmail.com>, grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Mouse coordinates in Map Window not
        following GUI settings projection
Message-ID: <20230816161659.GA24827 at example.com>
Content-Type: text/plain; charset=utf-8
On Wed, Aug 16, 2023 at 01:09:20PM -0300, Veronica Andreo wrote:
> This is what I have in GRASS 8.2.1?
> However, to make it work then, you need to select the preferred?CRS in the GUI
> main menu: Settings > Preferences > Projections
Nevermind, I synced my grass source tree to the latest release, rebuilt, and I
see the option in the GUI for alternative coordinates display now.
Cheers,
Eric
Subject: Digest Footer
End of grass-user Digest, Vol 208, Issue 16
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230818/4610f5c9/attachment.htm>
