[GRASS-user] Instructions for Linux Unbuntu install
Maris Nartiss maris.gis at gmail.com
Sat Aug 19 08:39:19 PDT 2023
Hello Philip,
the key message is inability to locate libgdal.so.30. My guess – along
with installing some programs your IT department also upgraded other
software. Just run `locate libgdal.so` in a terminal to get a list of
all GDAL versions installed on your system. If 3.0 is missing, then
you'll have to recompile GRASS (or install an update from repository
it came from).
Māris.
piektd., 2023. g. 18. aug., plkst. 22:28 — lietotājs Moffatt, Philip
via grass-user (<grass-user at lists.osgeo.org>) rakstīja:
> Hi there - I have a linux box with the following version of Unbuntu:
> Distributor ID: Ubuntu
> Description: Ubuntu 22.04.2 LTS
> Release: 22.04
> Codename: jammy
> A few weeks ago grass would start from the terminal and then my IT dept installed a program called "admin by request" and now the gui will not start. I get this error:
> petbuser at PETB:~$ grass
> Starting GRASS GIS...
> Cleaning up temporary files...
>           __________  ___   __________    _______________
>          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
>         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
>        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
>        \____/_/ |_/_/  |_/____/____/   \____/___//____/
> Welcome to GRASS GIS 8.2.2dev (3d37ee165c)
> GRASS GIS homepage:                      https://grass.osgeo.org
> This version running through:            Bash Shell (/bin/bash)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> See citation options with:               g.version -x
> If required, restart the GUI with:       g.gui wxpython
> When ready to quit enter:                exit
> Launching <wxpython> GUI in the background, please wait...
> To run a command as administrator (user "root"), use "sudo <command>".
> See "man sudo_root" for details.
> GRASS smrMFC/philip:~ > wxdigit.py: Could not load grass_vector.8.2.
> wxnviz.py: Could not load grass_g3d.8.2.
> g.findfile: error while loading shared libraries: libgdal.so.30: cannot open shared object file: No such file or directory
> Traceback (most recent call last):
>   File "/usr/lib/python3/dist-packages/wx/core.py", line 3282, in <lambda>
>     lambda event: event.callable(*event.args, **event.kw) )
>   File "/usr/local/grass82/gui/wxpython/wxgui.py", line 95, in show_main_gui
>     mainframe = GMFrame(parent=None, id=wx.ID_ANY, workspace=self.workspaceFile)
>   File "/usr/local/grass82/gui/wxpython/lmgr/frame.py", line 156, in __init__
>     self.statusbar = SbMain(parent=self, giface=self._giface)
>   File "/usr/local/grass82/gui/wxpython/lmgr/statusbar.py", line 38, in __init__
>     self.mask = SbMask(self.widget, self.giface)
>   File "/usr/local/grass82/gui/wxpython/lmgr/statusbar.py", line 87, in __init__
>     self.Refresh()
>   File "/usr/local/grass82/gui/wxpython/lmgr/statusbar.py", line 120, in Refresh
>     if gs.find_file(
> KeyError: 'name'
> The IT department has now uninstalled the admin by request program by my issue persists. I wanted to try and reinstall grass, but I have not been able to get passed the PPA steps listed online. I do not know what to do next.
> Thank you,
> plm
> ________________________________
> From: grass-user <grass-user-bounces at lists.osgeo.org> on behalf of grass-user-request at lists.osgeo.org <grass-user-request at lists.osgeo.org>
> Sent: Wednesday, August 16, 2023 12:00 PM
> To: grass-user at lists.osgeo.org <grass-user at lists.osgeo.org>
> Subject: grass-user Digest, Vol 208, Issue 16
> [EXTERNAL EMAIL]
> Send grass-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Furldefense.com%2Fv3%2F__https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-user__%3B!!JmPEgBY0HMszNaDT!pCOWNoUQztOHaiZEShGF2j8bqYxIW165dmf0v1mk36PlyrguZuVgkBvFT1KRtYD2mIW9Adki4s9VraI4iEVGD4nC0HoNlrAkjZk7KQ%24&data=05%7C01%7Cphilip.moffatt%40wsu.edu%7Ca372c25d2f0d49f4164b08db9e8b0b48%7Cb52be471f7f147b4a8790c799bb53db5%7C0%7C0%7C638278092265285702%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=7%2F7mqfEWOFR1G1ATL1ulfLL7n5NKjs%2F3Cm95bgD9%2FT4%3D&reserved=0
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
>    1. Re: Mouse coordinates in Map Window not following GUI
>       settings projection (Eric Patton)
> Message: 1
> Date: Wed, 16 Aug 2023 16:17:04 +0000
> From: Eric Patton <eric.r.patton at protonmail.com>
> To: Veronica Andreo <veroandreo at gmail.com>
> Cc: Anna Petr??ov? <kratochanna at gmail.com>, grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] Mouse coordinates in Map Window not
>         following GUI settings projection
> Message-ID: <20230816161659.GA24827 at example.com>
> Content-Type: text/plain; charset=utf-8
> On Wed, Aug 16, 2023 at 01:09:20PM -0300, Veronica Andreo wrote:
> > This is what I have in GRASS 8.2.1?
> > However, to make it work then, you need to select the preferred?CRS in the GUI
> > main menu: Settings > Preferences > Projections
> Nevermind, I synced my grass source tree to the latest release, rebuilt, and I
> see the option in the GUI for alternative coordinates display now.
> Cheers,
> Eric
> Subject: Digest Footer
> End of grass-user Digest, Vol 208, Issue 16
> https://lists.osgeo.org/mailman/listinfo/grass-user
