[GRASS-user] detrending time series maps
Veronica Andreo veroandreo at gmail.com
Fri Dec 22 04:45:28 PST 2023
Hello Ivan,
AFAIU you could use the slope and offset maps from t.rast.series within
t.rast.algebra to detrend the values of the maps within the strds,
something like "detrended_strds = trend_strds - (trend_strds*map(slope) +
map(offset))". Others suggest, to detrend by subtracting the previous
value, i.e. that would imply using the temporal algebra with the temporal
index, something like "detrended_strds = trend_strds[1] - trend_strds[0]".
I haven't tested any of these, just a couple of ideas ;-) However, I do not
know how this might interact with seasonality within data, or irregular
gaps.
hth somehow
Vero
El vie, 22 dic 2023 a las 5:10, Ivan Marchesini via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> Dear colleagues
> I would like to the advantage of the t.* modules for detrending a strd.
> In the strd I have earth observation data irregularly sampled (2 or 3
> times per month), in the period November-February, for 7 years. They are
> not equally spaced (i.e gaps have different duration)
> A simple t.rast.series analysis (opion=slope,offset) highlights that
> probably there is a descending trend when considering the maps ordered
> by id.
> I would like to fit a proper time depending fitting curve for each pixel
> and then subtract the function from the real data.
> any hints on how I can do this task exploiting the GRASS GIS modules or
> some simple bash/python scripting?
> thank you
> Ivan
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20231222/f8dcaf0b/attachment.htm>
