[GRASS-user] detrending time series maps
Ivan Marchesini ivan.marchesini at gmail.com
Sat Dec 23 05:53:47 PST 2023
Hi Veronica
Thank you. It goes in the direction of my idea evn if  my problem is
exactly trying to take into account the correct gaps between that data
I have another idea.
if it works I will come back here to explain how I did
thank you again
Ivan
On 22/12/23 13:45, Veronica Andreo wrote:
> Hello Ivan,
> AFAIU you could use the slope and offset maps from t.rast.series
> within t.rast.algebra to detrend the values of the maps within the
> strds, something like "detrended_strds = trend_strds -
> (trend_strds*map(slope) + map(offset))". Others suggest, to detrend by
> subtracting the previous value, i.e. that would imply using the
> temporal algebra with the temporal index, something like
> "detrended_strds = trend_strds[1] - trend_strds[0]".
> I haven't tested any of these, just a couple of ideas ;-) However, I
> do not know how this might interact with seasonality within data, or
> irregular gaps.
> hth somehow
> Vero
> El vie, 22 dic 2023 a las 5:10, Ivan Marchesini via grass-user
> (<grass-user at lists.osgeo.org>) escribió:
>     Dear colleagues
>     I would like to the advantage of the t.* modules for detrending a
>     strd.
>     In the strd I have earth observation data irregularly sampled (2 or 3
>     times per month), in the period November-February, for 7 years.
>     They are
>     not equally spaced (i.e gaps have different duration)
>     A simple t.rast.series analysis (opion=slope,offset) highlights that
>     probably there is a descending trend when considering the maps
>     ordered
>     by id.
>     I would like to fit a proper time depending fitting curve for each
>     pixel
>     and then subtract the function from the real data.
>     any hints on how I can do this task exploiting the GRASS GIS
>     modules or
>     some simple bash/python scripting?
>     thank you
>     Ivan
>     _______________________________________________
>     grass-user mailing list
>     https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20231223/c5a00de5/attachment.htm>
