[GRASS-user] grass82 with_opencl in Debian 12
bonushenricus bonushenricus76 at gmail.com
Mon Jun 26 22:21:46 PDT 2023
Hi and thanks
Yes QGIS runs the 3D rendering very well
For GRASS-GIS with the most simple
> CFLAGS=-O2 ./configure
i have at the end a problem in DEBIAN 12 because the pdal library
doesn't exist in the stable repository
so the configuration done:
> Package pdal was not found in the pkg-config search path.
> Perhaps you should add the directory containing `pdal.pc'
> to the PKG_CONFIG_PATH environment variable
> Package 'pdal', required by 'virtual:world', not found
> configure: error: *** Unable to locate suitable (>=1.7.1) PDAL
> library
The formal installation (from the website of PDAL) with conda doesn't
change anything.
Bye
Il giorno lun, 26/06/2023 alle 21.29 +0200, Richard Duivenvoorde ha
scritto:
> Wel there IS an openCL too :-) In QGIS:
> https://www.itopen.it/opencl-acceleration-now-available-in-qgis/
> 'naming is important' :-)
> Regards,
> On 6/26/23 16:04, Markus Neteler wrote:
> > Hi Enrico,
> > On Mon, Jun 26, 2023 at 3:59 PM bonushenricus
> > <bonushenricus76 at gmail.com> wrote:
> > > Hello everyone
> > > I installed Debian 12.
> > > I found grass-gis 8.2.1
> > > But it's not configured to work in opencl, and 3d rendering is
> > > very
> > > slow.
> > It is actually "openGL" to be installed, see
> > https://github.com/OSGeo/grass/blob/main/REQUIREMENTS.md#optional-packages
> > HTH,
> > Markus
