[GRASS-user] grass82 with_opencl in Debian 12
Maris Nartiss maris.gis at gmail.com
Mon Jun 26 22:41:35 PDT 2023
There are two options for PDAL – either disable completely (no import
tools for LAS files then) or provide paths for include and lib
directories. See ./configure --help for correct syntax of all
parameters. I have no idea if one can mix conda and native libs in a
single program.
Good luck,
Māris.
otrd., 2023. g. 27. jūn., plkst. 08:21 — lietotājs bonushenricus
(<bonushenricus76 at gmail.com>) rakstīja:
> Hi and thanks
> Yes QGIS runs the 3D rendering very well
> For GRASS-GIS with the most simple
> > CFLAGS=-O2 ./configure
> i have at the end a problem in DEBIAN 12 because the pdal library
> doesn't exist in the stable repository
> so the configuration done:
> > Package pdal was not found in the pkg-config search path.
> > Perhaps you should add the directory containing `pdal.pc'
> > to the PKG_CONFIG_PATH environment variable
> > Package 'pdal', required by 'virtual:world', not found
> > configure: error: *** Unable to locate suitable (>=1.7.1) PDAL
> > library
> The formal installation (from the website of PDAL) with conda doesn't
> change anything.
> Bye
> Il giorno lun, 26/06/2023 alle 21.29 +0200, Richard Duivenvoorde ha
> scritto:
> > Wel there IS an openCL too :-) In QGIS:
> > https://www.itopen.it/opencl-acceleration-now-available-in-qgis/
> > 'naming is important' :-)
> > Regards,
> > On 6/26/23 16:04, Markus Neteler wrote:
> > > Hi Enrico,
> > > On Mon, Jun 26, 2023 at 3:59 PM bonushenricus
> > > <bonushenricus76 at gmail.com> wrote:
> > > > Hello everyone
> > > > I installed Debian 12.
> > > > I found grass-gis 8.2.1
> > > > But it's not configured to work in opencl, and 3d rendering is
> > > > very
> > > > slow.
> > > It is actually "openGL" to be installed, see
> > > https://github.com/OSGeo/grass/blob/main/REQUIREMENTS.md#optional-packages
> > > HTH,
> > > Markus
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
