[GRASS-user] i.svm.* modules and manuals missing in GRASS 8.4 and online
Markus Neteler neteler at osgeo.org
Tue Mar 12 07:28:55 PDT 2024
On Tue, Mar 12, 2024 at 3:10 PM Veronica Andreo via grass-user
<grass-user at lists.osgeo.org> wrote:
> El mar, 12 mar 2024 a las 9:52, Veronica Andreo (<veroandreo at gmail.com>) escribió:
>> Hi all,
>> I want to try the new i.svm.* modules, but I discovered the manuals are not online at https://grass.osgeo.org/grass84/manuals/full_index.html#i and the modules are grey in the GUI. I installed the libsvm-dev package and added --with-SVM to the conf instruction, but that didn't work. I searched around but neither the wiki nor the html manual files have any hint about compilation with svm support. How should I specify the conf instruction?
> found it in the configure file in the source code: --with-libsvm
I can add it to the server compilation. But which library is needed?
It is missing from
grep -i svm REQUIREMENTS.md
thanks,
Markus
