[GRASS-user] i.svm.* modules and manuals missing in GRASS 8.4 and online
Veronica Andreo veroandreo at gmail.com
Tue Mar 12 07:32:11 PDT 2024
The library is LIBSVM, for Ubuntu it was libsvm-dev
El mar, 12 mar 2024 a las 10:29, Markus Neteler via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> On Tue, Mar 12, 2024 at 3:10 PM Veronica Andreo via grass-user
> <grass-user at lists.osgeo.org> wrote:
> > El mar, 12 mar 2024 a las 9:52, Veronica Andreo (<veroandreo at gmail.com>)
> escribió:
> >> Hi all,
> >> I want to try the new i.svm.* modules, but I discovered the manuals are
> not online at https://grass.osgeo.org/grass84/manuals/full_index.html#i
> and the modules are grey in the GUI. I installed the libsvm-dev package and
> added --with-SVM to the conf instruction, but that didn't work. I searched
> around but neither the wiki nor the html manual files have any hint about
> compilation with svm support. How should I specify the conf instruction?
> > found it in the configure file in the source code: --with-libsvm
> I can add it to the server compilation. But which library is needed?
> It is missing from
> grep -i svm REQUIREMENTS.md
> thanks,
> Markus
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240312/120ebd45/attachment.htm>
