[GRASS-user] How to avoid Grass84 compiling against the system Python3.6?
Hernán De Angelis variablestarlight at gmail.com
Wed Mar 20 23:38:40 PDT 2024
I understand you are using openSUSE Leap. At the moment I cannot check
which Python version is offered there as base. Are you sure you cant
install a newer version? If that is not possible you could perhaps install
a newer version using your own separate local environment, using miniforge,
for example.
I use openSUSE Tumbleweed and always build from source. Python 3.11 is the
base version now, with 3.12 starting to be rolled in. Perhaps it is not too
crazy to try TW?
Good luck!
Hernán
Den tors 21 mars 2024 01:23Barry Keeling via grass-user <
grass-user at lists.osgeo.org> skrev:
> Hi @grass-users,
> I posted the following on libera.chat#grass but it seemed like there
> isn't much activity on there (pls. excuse if I'm wrong on that).
> I spent the day learning how to compile the grass8.4dev source, and
> managed to get the app to compile, and fire up
> but there's a glitch, it compiled against the system python which is
> only v3.6 (not compatible based on REQUIREMENTS file)
> and I don't know how to point it at python v3.11.
> This is on OpenSuse 15.5 Linux, btw, and though the Grass application
> windows work well, I get errors in the console related mostly to python,
> when trying to use the various modules, for example using r.in.png.
> I've tried per-user setting python3 aliased to v3.11 in my .bashrc, but
> no luck Grass still shows v3.6 in Help/about/system ..
> I'm wondering whether I should use update-alternatives approach, and
> also wondering whether the problem might be related to wxpython3 being
> linked to the system python and not v3.11.
> I haven't compiled wxpython separately.
> I'm just hoping someone might be able to point me in the right direction
> Barry
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240321/c7936e70/attachment.htm>
