[GRASS-web] markus: web/grass62/binary/mswindows setup.ini,1.5,1.6
grass at intevation.de grass at intevation.de
Tue Dec 4 04:29:25 EST 2007
Author: markus
Update of /grassrepository/web/grass62/binary/mswindows
In directory doto:/tmp/cvs-serv22831
Modified Files:
	setup.ini
Log Message:
new binary from Glynn
Index: setup.ini
RCS file: /grassrepository/web/grass62/binary/mswindows/setup.ini,v
retrieving revision 1.5
retrieving revision 1.6
diff -u -d -r1.5 -r1.6
--- setup.ini	7 Sep 2007 04:47:23 -0000	1.5
+++ setup.ini	4 Dec 2007 09:29:23 -0000	1.6
@@ -2,8 +2,8 @@
 sdesc: "GRASS - Geographic Resources Analysis Support System"
 category: Database
 requires: cygwin gdal libintl8 libiconv2 freetype2 libpng12 fftw3 libncurses8 proj readline libtiff5 xterm xorg-x11-base lesstif tcltk-grass
-version: 6.2.2-2
-install: grass-6.2.2-2.cygwin.tar.bz2 16558552 54a26ee45cb43445a776c8bdface42c8
+version: 6.2.3-1
+install: grass-6.2.3-1.cygwin.tar.bz2 17221085 c2aa7eadc77c39e09089ae9efc852608
 @ gdal
 sdesc: "GDAL - Geospatial Data Abstraction Library"
More information about the grass-web mailing list
