[GRASS-web] Slovakia mirror
Markus Neteler neteler at osgeo.org
Sat Apr 9 01:55:29 EDT 2011
Dear Pavol,
we are using the DNS, so there should be no problem with the change.
Thanks for mirroring GRASS!
Markus
On Fri, Apr 8, 2011 at 10:46 AM, Pavol Cvengros
<pavol.cvengros at primeinteractive.net> wrote:
> Dear Markus,
> in next few days I am changing server to new/better hardware. I would like
> to check if rsync access for mirrors is on IP or DNS record.
> To be sure I am sending new IP address: 195.95.205.51
> Domain will stay as it is: www.grass.sk
> Best regards,
> Pavol
> On 24. 3. 2009 16:43, Markus Neteler wrote:
>> Hello Pavol,
>> I have added your site to the list - will show up in circa 30min from now.
>> Thanks for hosting GRASS,
>> Markus
>> On Tue, Mar 24, 2009 at 8:43 AM, Pavol Cvengros
>>> Hello Markus,
>>> I have changed my rsync to mirror from grass.osgeo.org.
>>> Best regards,
>>> Pavol
>>> On 23. 3. 2009 21:51, Markus Neteler wrote:
>>>> Hello Pavol,
>>>> I see that http://grass.sk/index.php
>>>> is lagging behind for 3 days... maybe you need to read from
>>>> grass.osgeo.org?
>>>> The rsync server responds well.
>>>> Best regards,
>>>> Markus
>>>> On Sun, Mar 22, 2009 at 12:18 PM, Pavol Cvengros
>>>>> Hello,
>>>>> rsync server on my server is set. Only one repository available from
>>>>> sync
>>>>> and that is grass. Maximum 20 parallel connections.
>>>>> Please test it and if everything will be ok I would like to apply for
>>>>> tier 1
>>>>> mirror server.
>>>>> Rsync server: grass.sk
>>>>> Best regards,
>>>>> Pavol
>>>>> On 11. 3. 2009 9:22, Markus Neteler wrote:
>>>>> Hello Pavol,
>>>>> On Wed, Mar 11, 2009 at 7:48 AM, Pavol Cvengros
>>>>> Hello,
>>>>> I am running Slovakia mirror on my private server with courtesy of
>>>>> Prime
>>>>> Interactive Ltd. for a long time on domain grass.sk
>>>>> I found that you are looking for tier 1 mirrors. What is needed to
>>>>> become
>>>>> one? Is the only one condition to run rsync server to provide mirroring
>>>>> capabilities for tier 2 server?
>>>>> that's right! Just "be open", say, permit others to rsync from you.
>>>>> All this originates from the times that the master site was
>>>>> grass.itc.it
>>>>> with
>>>>> limited bandwiths. grass.osgeo.org is well connected (thanks to
>>>>> telascience.org)
>>>>> so that we reach 2.x TB (!) peaks per months.
>>>>> However, mirrors don't harm and we prefer a semi-decentralized
>>>>> infrastructure
>>>>> in case the North Atlantic or Pacific network bones get cut. Still we'd
>>>>> remain
>>>>> online :)
>>>>> If you have enough bandwidth you may enable others to rsync from you.
>>>>> Then please ping us here to update the mirror list (next of your mails
>>>>> will
>>>>> go through directly).
>>>>> Best regards,
>>>>> Markus
More information about the grass-web mailing list
