[winGRASS] Terminal Error
Malcolm Blue mblue at nb.sympatico.ca
Fri Aug 24 06:48:23 EDT 2001
Hi again,
It looks like there is a command in the Xinstall.sh for XFree86 that didn't
run correctly and which should set up the xterm entries.
In a Cygwin bash command shell execute:
tic /usr/X11R6/lib/X11/etc/xterm.termcap      //(Xinstall.sh has
xterm.terminfo)
This should set up the right xterm definitions so that grass will run
correctly in XFree86 with TERM=xterm.
Malcolm
-----Original Message-----
From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
Behalf Of Malcolm Blue
Sent: Thursday, August 23, 2001 10:27 PM
To: Andreas.Lange at Rhein-Main.de; Taravudh Tipdecho
Cc: wingrass at grass.itc.it
Subject: RE: [winGRASS] Terminal Error
I've finally upgraded Cygwin, Xfree86 and Grass for the first time since
April.  I had the same error message that Taravudh reported.
To fix this:  Look in /usr/lib/terminfo/x  to see what the xterm* options
are.
I tried xterm-xf86-v40 and it seems to be working.  Use
'TERM=xterm-xf86-v40'.  I don't think that this is the best solution since
g.list reports 'WARNING: Terminal is not fully functional', even though it
seems to work.  We might need to experiment with the choices a bit more.
tcltkgrass operates strangely but I think that's because of twm.  I think
I'll also check around for another window manager for Cygwin/XFree86.
Perhaps LessTif mwm?
In the meantime, try the above to get the monitors working.  Let the list
know if you find an xterm terminal definition that doesn't result in
warnings. ;)
Malcolm
Behalf Of Andreas Lange
Sent: Wednesday, August 22, 2001 5:49 AM
To: Taravudh Tipdecho
Subject: Re: [winGRASS] Terminal Error
Hi Taravudh,
this is a problem of your XFree86 installation for xterm IMHO.
A quick fix is to type
export TERM=vt100
before you start grass5.
I have currently the same problem and will look if i find a solution.
Does someone know what the correct terminal for the xterm under cygwin
is?
Andreas
Taravudh Tipdecho wrote:
> Hi all,
> According to instruction, I installed Cygwin/XFree86 running on
> Windows2000. Anyway, it was a problem from displaying which was "Error
> opening terminal:xterm. Invalid resource file, removing
> /home/taravudh/.grassrc5.  This dialog is come after Grass welcome
> message.
> Could you please give me some hints?
> Thanks.
> Taravudh Tipdecho
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.265 / Virus Database: 137 - Release Date: 7/18/2001
Outgoing mail is certified Virus Free.
More information about the grass-windows mailing list
