[winGRASS] Terminal Error
Andreas Lange
Andreas.Lange at Rhein-Main.de
Fri Aug 24 11:50:37 EDT 2001
Hi Malcolm,
thanks for the fix, this worked. The Xinstall.sh had some more error
messages, but i noticed nothing missing until now.
I hope that in the not to far future the keyboard management will work
too. It is still flawed.
cu,
Andreas
Malcolm Blue wrote:
> Hi again,
> It looks like there is a command in the Xinstall.sh for XFree86 that didn't
> run correctly and which should set up the xterm entries.
> In a Cygwin bash command shell execute:
> tic /usr/X11R6/lib/X11/etc/xterm.termcap //(Xinstall.sh has
> xterm.terminfo)
> This should set up the right xterm definitions so that grass will run
> correctly in XFree86 with TERM=xterm.
> Malcolm
> -----Original Message-----
> From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
> Behalf Of Malcolm Blue
> Sent: Thursday, August 23, 2001 10:27 PM
> To: Andreas.Lange at Rhein-Main.de; Taravudh Tipdecho
> Cc: wingrass at grass.itc.it
> Subject: RE: [winGRASS] Terminal Error
> Hi,
> I've finally upgraded Cygwin, Xfree86 and Grass for the first time since
> April. I had the same error message that Taravudh reported.
> To fix this: Look in /usr/lib/terminfo/x to see what the xterm* options
> are.
> I tried xterm-xf86-v40 and it seems to be working. Use
> 'TERM=xterm-xf86-v40'. I don't think that this is the best solution since
> g.list reports 'WARNING: Terminal is not fully functional', even though it
> seems to work. We might need to experiment with the choices a bit more.
> tcltkgrass operates strangely but I think that's because of twm. I think
> I'll also check around for another window manager for Cygwin/XFree86.
> Perhaps LessTif mwm?
> In the meantime, try the above to get the monitors working. Let the list
> know if you find an xterm terminal definition that doesn't result in
> warnings. ;)
> Malcolm
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
More information about the grass-windows
