[winGRASS] installation problems!
Viktor Toth donvito at tres.blki.hu
Fri May 25 02:40:34 EDT 2001
Malcolm!
I do have this version (8.0.5) of tcltk installed.
As a matter of fact I reinstalled it but the GRASS
still rejecting my ideas.
_______________________________________
GRASS:/ >exec: wish:  not found
As I mentioned previously, I'm completely dumb
in this field, so please be tender to me :o))))
take care
cheers
viktor
At 07:32 AM 5/25/01, you wrote:
>Viktor,
>I didn't realize that I had replied directly to you the last time.  I am
>redirecting this back to the mailing list.
>The tcltkgrass problem looks like another known cygwin bug.  There is a
>recompiled
>version of tcl/tk on the grass ftp site called:
>xtcltk8.0.5-CYGWIN_NT-4.0-20010405-1.tar.gz
>This version does not have the path conversion problems that caused the
>error you
>describe.  Download that file and install as per the grass binary installation
>instructions.  Make sure that /usr/local/bin is in your path.
>Cheers,
>Malcolm
>Toth Viktor wrote:
> > Malcolm!
> > Your help was of uppermost importance and precision, since I managed to
> > successfully install the GRASS.
> > I'm grateful to you beyond all imaginable borders. Cheers.
> > Since you was so helpful (i really appreciate it) can I ask another
> question?
> > I tried to run tcltkgrass5, but the system does not repsonded ("no such
> > file or directory").
> > What I did wrong?
> > Should I install the tcltk files one more time?
> > The GRASS manual says that the install file contains the necessary
> > tcltkgrass5 files.
> > Thanx a lot for you precious help!!!!!
> > viktor
> > At 00:11 2001.05.23., you wrote:
> > >Viktor,
> > >There are a few gotcha's that we have encountered with Cygwin, but I
> will need
> > >more information from you before I (or someone else) can tell you what is
> > >happening in your case.  Can you provide more output from the install
> program?
> > >One possibility is that you are trying to run the grass5install.sh
> script from
> > >the root directory.  If so, copy this file and the grass archive to a
> > >subdirectory and try it there.  Otherwise, include the output from
> install,
> > >before the error you mentioned.  Even if they don't look like errors,
> they may
> > >have clues as to the problem.
> > >Malcolm
> > >Viktor Toth wrote:
> > > > Hi Everybody!
> > > > I installed the latest Cygwin/XFree (4.0.3), which is by the way
> looks like
> > > > it works perfectly, and than tried to install the GRASS (5.0beta12)
> which
> > > > stopped after installing several files and directories with the
> following
> > > > message - "an error occurred while installing binaries (are you root
> > > > user?)!". Since I'm completely new to this things (both Cygwin and
> GRASS)
> > > > can anybody explain me (like to a 4 year old) what I f at cked up
> during the
> > > > install.
> > > > Cheers
> > > > vito
> > > > _______________________________________________
> > > > winGRASS mailing list
> > > > winGRASS at www.geog.uni-hannover.de
> > > > http://www.geog.uni-hannover.de/mailman/listinfo/wingrass
More information about the grass-windows mailing list
