[winGRASS] cannot find Init.sh
Malcolm Blue mblue at nb.sympatico.ca
Thu May 31 19:29:46 EDT 2001
Ziyadin,
I've redirected this email to the grass5 list (but cc'd to the wingrass list in
case you aren't subscribed to grass5 yet).  As Markus said it is more
appropriate there.
Often when a large number of modules don't compile, there is a problem with
compiling one of the core libraries.  libgis and libraster are likely culprits.
Dependencies for compiling these libraries are largely checked by the configure
program.  These will likely show up as errors in the linking process.  If so,
let us know the error messages from the gmake5 process, as described by Markus,
and from the configure step.
Malcolm
Markus Neteler wrote:
> On Thu, May 31, 2001 at 10:04:54AM +0300, ziyadin wrote:
> > Hi Markus and Malcome,
> > Thank you for your recomendations. At first, I
> > compiled source code of Baylor last month.
> > The problem  was that most of the modules (270 command)
> > were not compiled.
> > I tried to do it manually using gmake5 but no luck.
> > That is why I tried to install a precompiled version.
> > This time I got the source code from Hannover (grass5.0.0pre1)
> > but, it is the same problem. Forexample none of the raster or mapdev
> > was install. The followings are a few examples from the error.log file.
> > Module source code not installed: src/raster/r.what (ignored)
> > Module source code not installed: src/raster/r.surf.idw2 (ignored)
> > Module source code not installed: src/mapdev/v.surf.rst (ignored)
> Hi Ziyadin,
> these bugs are highly interesting for us. You can get the error message
> after typing (adjust the platform name):
>  bin.sparc-sun-solaris2.8/gmake5 src/raster/r.what
>  bin.sparc-sun-solaris2.8/gmake5 src/raster/r.surf.idw2
>  bin.sparc-sun-solaris2.8/gmake5 src/mapdev/v.surf.rst
> Please send the error message to me.
> BTW: you are posting to the Windows/GRASS mailing list. Please
> post the next messages to "grass5" not to bother the subscribers
> here, thanks.
> http://www.geog.uni-hannover.de/grass/grassdevel.html
> I am sure we can quickly fix the problems.
> Kind regards
>  Markus Neteler
> > Malcolm Blue wrote:
> > > Hi,
> > > You should download the more recent binaries.  Grass5 pre-release is
> > > available now (after beta 12), or will be available soon for most
> > > supported platforms.  Beta9 was replaced by beta10 after 1 day because
> > > of "severe installation" bugs.  If the new solaris binaries are not
> > > available now, they should be very soon.  Since there have been a lot of
> > > improvements since beta9, it will be worth a short wait.
> > > If you can't wait, it is usually straight forward to compile yourself.
> > > Instructions are available at the grass web site and in the source
> > > download.
> > > Malcolm
> > > ziyadin wrote:
> > > > Dear grass user,
> > > > I have intalled grass5.0beta9_solaris binaries.
> > > > When  i give the command grass5 i get this
> > > > error mesage
> > > > /usr/local/bin/grass5: /usr/local/grass5/etc/Init.sh: not found
> > > > If i fallow the default setup grass is stored in
> > > > /usr/local/grass5/grass5.0beta9_solaris/grass5(/dev etc...)
> > > > I came around this problem and now it is in
> > > > usr/local/grass5(/dev etc...)
> > > > I could not find this script. Am I supposed to create it myself?
> > > > I would be glad if I could get any help.
> > > > Cheers,
> > > > Ziyadin
> > > > ____________________________________________________________
> > > > Ziyadin CAKIR                          Tel:++90 +212 2856320
> > > > Istanbul Technical University          Fax:++90 +212 2856210
> > > > Mining Faculty, Geology Department    Mail:cakirz at itu.edu.tr
> > > > Maslak/Istanbul/TURKEY
> > > > winGRASS mailing list
> > > > winGRASS at www.geog.uni-hannover.de
> > > > http://www.geog.uni-hannover.de/mailman/listinfo/wingrass
> Markus Neteler *  University of Hannover
> Institute of Physical Geography and Landscape Ecology
> Schneiderberg 50 * D-30167 Hannover * Germany
> Tel: ++49-(0)511-762-4494  Fax: -3984
More information about the grass-windows mailing list
