[winGRASS] more in Wingrass?
Markus Neteler neteler at itc.it
Fri Sep 7 12:13:02 EDT 2001
On Fri, Sep 07, 2001 at 08:54:31AM -0700, Bob Sandefur wrote:
> Hi-
> Question:
>  Does more exist in cygwin (or grass5) and if so where is it?
> Background:
>  After Boss Billy Gates dog  XP (prerelease build 2505) ate one of my hard
>  drives (maybe it wasn't XP but the directory got trashed when I was
>  running XP), I went back to windows 2000 with a clean install, installed
>  cygwin from net and installed grass5, which based on limited testing
>  works okay. However, in console mode m.proj failed to list projection
>  properly because more was not found.  To fix this in /bin I cp'ed
>  less.exe to more.exe and m.proj list works fine.
> thanx
Hi Bob,
sorry, I can't help you with the "more" question, but a small hint:
There is a GRASS_PAGER variable:
http://grass.itc.it/gdp/html_grass5/env_vars.html
which you can be use for a general change for all (more or less)
GRASS modules.
Best regards
 Markus
More information about the grass-windows mailing list
