[winGRASS] more in Wingrass?
Bob Sandefur rls at pincock.com
Fri Sep 7 11:54:31 EDT 2001
Hi-
Question:
 Does more exist in cygwin (or grass5) and if so where is it?
Background:
 After Boss Billy Gates dog  XP (prerelease build 2505) ate one of my hard drives (maybe it wasn't XP but the directory got trashed when I was running XP),  I went back to windows 2000  with a clean install, installed cygwin from net and installed grass5, which based on limited testing works okay. However, in console mode m.proj failed to list projection properly because more was not found.  To fix this in /bin I cp'ed less.exe to more.exe and m.proj list works fine.
thanx
bob
More information about the grass-windows mailing list
