[winGRASS] trouble with d.mon
Ed Davison bfdi533 at cbacc-security3.bus.utexas.edu
Fri Oct 10 15:29:31 EDT 2003
I have installed grass on Cygwin with the install script and have
successfully started GRASS.
I am now trying to start a monitor with 'd.mon start=x0' using X-Win X
Server and get the following error:
Dialog Box:
Title: XDRIVER.exe - Unable To Locate Component
Content: This application has failed to start because libX11.dll was not
found. Re-installing the applicatoi may fix this problem.
Button: OK
I used the batch file startxwingrass.bat from the web site to start
grass and the X Server.
Any help would be appreciated.
Ed Davison
More information about the grass-windows mailing list
