[winGRASS] grass on cygwin first run
Glynn Clements glynn.clements at virgin.net
Fri Jan 9 13:04:30 EST 2004
-LПрокопьев Евгений wrote:-A
> I can't run grass as described in
> http://grass.itc.it/grass5/binary/windows_cygnus/cygwin_grass50bininstall.html
> nviz elevation.dem vect=roads & can't run because it require tcl84.dll.
> I installed tcltk 8.4.4 from ActiveTcl, but nviz can't run with
> following errors:
If NVIZ requires tcl84.dll, it hasn't been compiled correctly, and
won't work. Did you get a binary GRASS package, or did you build it
yourself?
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows mailing list
