[winGRASS] Problems with winGRASS Web Links
Glynn Clements glynn.clements at virgin.net
Sun Sep 19 13:43:12 EDT 2004
Randy Schnoes wrote:
> I assume the Web page link is incorrect.  It probably was supposed to
> point to one site, but accidently points to the tcl/tk site.
> Can someone point me to a better URL with accurate winGRASS download
> links?  How would you advise me to proceed to obtain the winGRASS
> binaries?  Is winGRASS still available for use?
Those links are correct, in that the Cygwin GRASS binaries used to
live in those directories when they existed. I'm not sure why they
were removed. However, it appears that if you want to use GRASS on
Cygwin, you will have to build it from the source code.
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows mailing list
