[winGRASS] m.proj s.in.ascii s.to.rast
Martin du Saire mdusaire at umn.edu
Thu Apr 14 11:44:16 EDT 2005
I just installed GRASS6.0, the installation was a lot easier than
installing 5.0 a year ago.
What happened to m.proj, s.in.ascii, and s.to.rast?
Last time I worked with GRASS (Feb 2004), I was trying to calculated the
landcover statistics in a 500km radius around a research site based on the
NLCD from USGS:
a)  I used m.proj2 to convert my site locations to the projection
corresponding to the landcover data I was using.
b)  defined the site with s.in.ascii, and converted it to a raster using
s.to.rast.
c)  created the buffer zone using r.buffer
d)  patched the landcover map in the buffer zone with r.patch -z
e)  calculated statistics with r.stat -c
I gather these commands no longer exist. In that case I need some help
figuring out how to do this in 6.0.
Thanks.
Martin
More information about the grass-windows mailing list
