[winGRASS] Re: winGRASS and cygwin, and GIS lock issue
Jeff McKenna jmckenna at dmsolutions.ca
Mon Dec 4 08:55:22 EST 2006
I have been quietly battling this same error, with GRASS 63 and 6.2.0,
on Cygwin, and following all discussions.  I've seen people say that
it's due to a missing PostgreSQL on the machine (not true in my case),
and now this latest news (although it seems to apply only to
native-GRASS users, whereas I'm trying to use Cygwin...in any case the
locking trick doesn't work for me either).
Anyway I'll keep trying.
jeff
Isaac Ullah wrote:
> Hi Listers,
>     Jonathan is exactly right about the issues with the new winGRASS for
> those of us that previously had CYGWIN with GRASS installed on our
> machines. Removing CYGWIN is not easy, however, as there is no
> "uninstall" option for CYGWIN. I had to search around for a solution:
> Apparently, some of the files in the Cygwin directory are given very
> different perissions from ordinary files. They are assigned "system" as
> their owner, and even if you are an administrator, you cannot delete
> them with the default way windows wants to have things organized. In a
> standard windows exploer window, you have to click tools > folder
> options, and select the "view" tab from the dialogue box that pops up.
> You have to scroll down the list, and uncheck the box next to "use
> simple file sharing". Now when you right click on an item, and select
> proerties, there are several new tabs in the window. You must go to the
> "security" tab, and change the owner ship and permissions associated
> with those cygwin files that are apparently undeleteble. Once that is
> done, you should now be able to manually delete everything asscociate
> with cygwin (which conveniently is all in the cygwin directory).
>    Also, Jonathan, your solution to the Locking problem is probably
> okay. I know that it was put in there in the Linux version to prevent
> more than one user at a time from reading and writing on the same set of
> GRASS files. This was only needed if your GIS database was located on a
> server or was shared over a network. Since this does not apply to the
> curretn WinGRASS, you can actually simply delete those lines without any
> issue. In fact, that may be something that should be done to the
> WinGRASS packages anyway...
> Cheers,
> Isaac
>     Message: 4
>     Date: Sat, 2 Dec 2006 14:24:13 -0500
>     From: "Jonathan Aguero" <jua130 at psu.edu <mailto:jua130 at psu.edu>>
>     Subject: RE: [winGRASS] grass native installation problem
>     To: "'Bryan Keith'" < bryan at geomega.com <mailto:bryan at geomega.com>>,
>     "'Jack'"
>             <jacques.charroy at laposte.net
>     <mailto:jacques.charroy at laposte.net>>
>     Cc: wingrass at grass.itc.it <mailto:wingrass at grass.itc.it>
>     Message-ID:
>             <!~!UENERkVCMDkAAQACAAAAAAAAAAAAAAAAABgAAAAAAAAATR1TnoRRqU2OBfkDJYrxesKAAAAQAAAAoAwKhMpEb0isJHsu0qEyhAEAAAAA at psu.edu
>     <http://psu.edu>>
>     Content-Type: text/plain;       charset="us-ascii"
>     Brian and Jacques,
>     I just had the same problem with my WinXP system. It seems that the
>     problem
>     was related to my old Cygwin installation. I removed cygwin and
>     clean up the
>     environmental variables related and then GRASS worked.
>     If the CYGWIN variable is defined in your system, the grass init script
>     assumes that the shell is bash instead of the bourne shell (sh) used by
>     MINGW/msys.
>     I hope this help you guys.
>     Jonathan Aguero Valverde
>     Research Assistant and Ph.D. Candidate
>     Pennsylvania State University
>     The Pennsylvania Transportation Institute
>     201 Transportation Research Building
>     University Park, PA 16802
>     www.personal.psu.edu/jua130 <http://www.personal.psu.edu/jua130>
>     -----Original Message-----
>     From: wingrass-bounces at grass.itc.it
>     <mailto:wingrass-bounces at grass.itc.it>
>     [mailto:wingrass-bounces at grass.itc.it
>     <mailto:wingrass-bounces at grass.itc.it>]
>     On Behalf Of Bryan Keith
>     Sent: Monday, October 02, 2006 10:12 AM
>     To: Jack
>     Subject: Re: [winGRASS] grass native installation problem
>     I'm having the exact same problem.  Anyone know how to solve it?
>     Bryan
>     Jacques Charroy wrote:
>      > Hi,
>      > I recently installed the native wingrass package on two computers. On
>      > one everything went well, but on the next one gis.m never managed to
>      > start, although GRASS starts alright. Upon starting gis.m I get
>     an error
>      > box saying the following:
>      > Error in startup script
>      > Can't read "parts(n)": no such variable
>      > while executing
>      > "MapCanvas::zoom_new $mon $parts(n) $parts(s).......(more)
>      > (procedure "MapCanvas::zoom_gregion" line 11)
>      > invoked from within.......and so forth with 5 or six levels of
>     function
>      > calls until:
>      > invoked from within
>      > (file "C:/msys/1.0/local/grass/etc/gm/gm.tcl" line 522)
>      > Has someone else had the same problem? any ideas how to solve that?
>      > Thanks,
>      > Jacques Charroy
>      > _______________________________________________
>      > winGRASS mailing list
>      > winGRASS at grass.itc.it <mailto:winGRASS at grass.itc.it>
>      > http://grass.itc.it/mailman/listinfo/wingrass
>     Message: 5
>     Date: Sat, 2 Dec 2006 14:54:49 -0500
>     From: "Jonathan Aguero" < jua130 at psu.edu <mailto:jua130 at psu.edu>>
>     Subject: RE: [winGRASS] Installation problem native win version
>     To: <wingrass at grass.itc.it <mailto:wingrass at grass.itc.it>>, "'Neil
>     Falconer'"
>             < neil.falconer at absamail.co.za
>     <mailto:neil.falconer at absamail.co.za>>
>     Message-ID:
>             <!~!UENERkVCMDkAAQACAAAAAAAAAAAAAAAAABgAAAAAAAAATR1TnoRRqU2OBfkDJYrxesKAAAAQAAAABBW/pD+cq0OpkdSDNT/yLAEAAAAA at psu.edu
>     <http://psu.edu>>
>     I worked more in the locking problem today and found a partial solution.
>     I commented the following lines in the /grass/etc/init.sh file:
>     # Check for concurrent use
>     #lockfile="$LOCATION/.gislock"
>     #"$ETC/lock" "$lockfile" $$
>     #case $? in
>     #    0) ;;
>     #    1)
>     #    echo $USER is currently running GRASS in selected mapset.
>     Concurrent
>     use not allowed.
>     #    rm -rf "$tmp"  # remove session files from tmpdir
>     #    exit 1 ;;
>     #    echo Unable to properly access "$lockfile"
>     #    echo Please notify system personel.
>     #    exit 1 ;;
>     #esac
>     The symbol # before the line made it a comment and the locking is not
>     performed by GRASS. As mention in other mails, concurrence might not
>     be a
>     problem in windows.
>     It seems like many other people experienced this problem but GRASS
>     keeps
>     going while in some other systems crashes, it might be a difference
>     in how
>     updated XP is.
>     Note that this is a very pedestrian solution, GRASS programmers
>     could come
>     up with a better one but in the mean time this may get you going with
>     WINGRASS.
>     On Behalf Of Jonathan Aguero
>     Sent: Friday, October 13, 2006 8:57 AM
>     To: wingrass at grass.itc.it <mailto:wingrass at grass.itc.it>
>     Subject: [winGRASS] Installation problem native win version
>     Dear listers,
>     I downloaded and installed the new native version of winGRASS
>     yesterday. The
>     installation apparently was successful but when I tried to start
>     GRASS after
>     I selected the location and mapset it flashed the following message:
>     Locking is not supported in Windows!
>     and close the window.
>     I did not install PG 8.1 since I have the 8.0 version and I wanted
>     to save
>     the trouble so I modify the grass.bat the see at the 8.0 folder.
>     Anyway the
>     problem seems more OS related than PG related. My OS is XP
>     professional SP2.
>     Thanks in advance for your help.
>     -------------- next part --------------
>     An HTML attachment was scrubbed...
>     URL:
>     http://grass.itc.it/pipermail/wingrass/attachments/20061202/82c698ce/attachment.html
>     End of winGRASS Digest, Vol 6, Issue 1
> Isaac I Ullah, M.A.
> Archaeology PhD Student,
> ASU School of Evolution and Social Change
> Research Assistant,
> Mediterranean Landscape Dynamics Project
> isaac.ullah at asu.edu <mailto:isaac.ullah at asu.edu>
> ullah at archaeologist.com <mailto:ullah at archaeologist.com>
> http://www.public.asu.edu/~iullah
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
More information about the grass-windows mailing list
