[winGRASS] Installation problem native win version
Jeff McKenna jmckenna at dmsolutions.ca
Thu Dec 7 15:27:00 EST 2006
It turns out i did have this same issue with grass-native, thanks Jonathan.
(bye-bye Cygwin)
jeff
Jonathan Aguero wrote:
> I worked more in the locking problem today and found a partial solution.
> I commented the following lines in the /grass/etc/init.sh file:
> # Check for concurrent use
> #lockfile="$LOCATION/.gislock"
> #"$ETC/lock" "$lockfile" $$
> #case $? in
> #    0) ;;
> #    1)
> #    echo $USER is currently running GRASS in selected mapset.
> Concurrent use not allowed.
> #    rm -rf "$tmp"  # remove session files from tmpdir
> #    exit 1 ;;
> #    echo Unable to properly access "$lockfile"
> #    echo Please notify system personel.
> #    exit 1 ;;
> #esac
> The symbol # before the line made it a comment and the locking is not
> performed by GRASS. As mention in other mails, concurrence might not be
> a problem in windows.
> It seems like many other people experienced this problem but GRASS keeps
> going while in some other systems crashes, it might be a difference in
> how updated XP is.
> Note that this is a very pedestrian solution, GRASS programmers could
> come up with a better one but in the mean time this may get you going
> with WINGRASS.
> Jonathan Aguero Valverde
> Research Assistant and Ph.D. Candidate
> Pennsylvania State University
> The Pennsylvania Transportation Institute
> 201 Transportation Research Building
> University Park, PA 16802
> www.personal.psu.edu/jua130
> -----Original Message-----
> *From:* wingrass-bounces at grass.itc.it
> [mailto:wingrass-bounces at grass.itc.it] *On Behalf Of *Jonathan Aguero
> *Sent:* Friday, October 13, 2006 8:57 AM
> *To:* wingrass at grass.itc.it
> *Subject:* [winGRASS] Installation problem native win version
> Dear listers,
> I downloaded and installed the new native version of winGRASS yesterday.
> The installation apparently was successful but when I tried to start
> GRASS after I selected the location and mapset it flashed the following
> message:
> Locking is not supported in Windows!
> and close the window.
> I did not install PG 8.1 since I have the 8.0 version and I wanted to
> save the trouble so I modify the grass.bat the see at the 8.0 folder.
> Anyway the problem seems more OS related than PG related. My OS is XP
> professional SP2.
> Thanks in advance for your help.
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
More information about the grass-windows mailing list
