[winGRASS] Installation problem
Graham Smith graham.smith at myotis.co.uk
Fri Feb 17 09:18:06 EST 2006
> > I am a bit a sea with this, as I don't even know how to
> start the Bash
> > shell.
> > However, if I go into the directory and double click on
> bash.exe a Dos
> > window opens called C:\cygwin\bin\bash.exe.
> > Typing startx (plus return) in this window, gives me a "command not
> > found error"
> > I have also found on the WINGrass Wiki, that I hadn't found when I
> > sent my original post, that other people have had the same problem.
> > The advice there is to run C:\cygwin\usr\X11R6\bin\startxwin, then
> > type "Grass60.bat"
> > This opens a "Windows like" Bash shell, but when I type "Grass" or
> > "Grass60.bat" and hit return, I get a command not found error.
> > Grass60.bat is in the C:\cygwin directory.
> > I have tried manually changing the active directory with cd
> c:\cygwin
> > but I cannot get a "\" in Bash. the "\" key gives me a "<"
> symbol. I
> > have tried to find where the "\" has been remapped, but without
> > success. It only affects Bash.
> > I wonder if I should just re-install. To uninstall can I
> simply delete
> > the Cygwin directory?
> > Thanks again.
> > Graham
> No need to re-install. You open a bash shell by double
> clicking the Cygwin icon on your desktop, or by picking the
> "Cygwin Bash Shell" in your program menu. The Bash Shell
> looks like a DOS shell.
> In the Bash shell type 'startx'. This starts a graphical
> windowing system. If you get command not found, the run your
> Cygwin setup.exe and install  the X11 windowing system.
> When you are working within the Cygwin environment, you will
> generally not run a .BAT file. The proper command would be
> 'grass6' or 'grass60'
> (I forget which).
> It's best pratice to reply to the list, not to the
> individual. In that way everyone on the list has the
> oppertunity to participate.
Rich,
I thought I had replied to the group, but I now see that simply hitting
reply, sends it to the sender rather than the group.
Following advice from elsewhere, I have re-run the set up and uninstalled 6
and installed 6.1 in its place. This now runs as expected. Except I have a
new problem in that I am now getting an error telling me that my current
group is mkpasswd, which indicates that I need to rebuild /etc/passwd, It
gives the commands to do this, but I am not sure where I use them unless it
is in Bash.
However, having got to this stage, it is obviously now time to start reading
the manual.
Thanks for your help.
Graham
More information about the grass-windows mailing list
