[winGRASS] RE: winGRASS digest, Vol 1 #381 - 1 msg
Gerry James gjames at bgcengineering.ca
Wed Jan 11 11:31:06 EST 2006
 Karl,
There are a number of image formats supported in gdal that are not
directly supported in WinGrass.  I was never able to import MrSid for
example.  There is software on the internet that will allow you to
convert the ECW into a geotiff such as FWTools
(http://fwtools.maptools.org/).
Hope this helps.
Gerry James, Geomatics Manager
BGC Engineering Inc.
Geomatics and Information Management Group
604.684.5900 x.126
-----Original Message-----
From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]
On Behalf Of wingrass-request at grass.itc.it
Sent: Tuesday, January 10, 2006 3:01 AM
To: wingrass at grass.itc.it
Subject: winGRASS digest, Vol 1 #381 - 1 msg
Send winGRASS mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	http://grass.itc.it/mailman/listinfo/wingrass
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
When replying, please edit your Subject line so it is more specific than
"Re: Contents of winGRASS digest..."
Today's Topics:
   1. error on import of ECW/ERMapper Compressed Wavelets
(karl.sommer at dpi.vic.gov.au)
--__--__--
Message: 1
Date: Tue, 10 Jan 2006 14:57:47 +1100
Subject: [winGRASS] error on import of ECW/ERMapper Compressed Wavelets
I have been trying to import a file of the format described below using
the
r.in.gdal in WinGrass6.0
r.in.gdal input=/home/ks80/data/Orthophotos/Colignan_NAT_20X.ecw
output=Col title=Col ERROR 4:
`/home/ks80/data/Orthophotos/Colignan_NAT_20X.ecw' not recognised as a
supported file format.
I always get the above message 'not recognized as a supported file
format'.
According to the documentation the format should be supported
Would anyone be able to help me??
Cheers
Karl
----FILE FORMAT according to gdalinfo-------------------
C:\cygwin\home\ks80\data\Orthophotos>gdalinfo Colignan_NAT_20X.ecw
Driver: ECW/ERMapper Compressed Wavelets Size is 52908, 74162 Coordinate
System is:
PROJCS["MGA54",
    GEOGCS["GEOCENTRIC DATUM of AUSTRALIA",
        DATUM["GDA94",
            SPHEROID["GRS80",6378137,298.257222101]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",141],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",10000000],
    PARAMETER["false_northing",500000],
    UNIT["Meter",1]]
Origin = (614120.000000,6194000.050000)
Pixel Size = (0.30000000,-0.30000000)
Corner Coordinates:
Upper Left  (  614120.000, 6194000.050) (120d 0'45.45"E,695d28'34.82"N)
Lower Left  (  614120.000, 6171751.450) ( 63d55'10.07"E,671d 4'32.39"N)
Upper Right (  629992.400, 6194000.050) (101d23'29.63"E,685d53'19.03"N)
Lower Right (  629992.400, 6171751.450) ( 45d59'34.29"E,661d49'51.09"N)
Center      (  622056.200, 6182875.750) ( 82d30'14.90"E,678d25'33.52"N)
Band 1 Block=52908x1 Type=Byte, ColorInterp=Red
  Overviews: arbitrary
Band 2 Block=52908x1 Type=Byte, ColorInterp=Green
Band 3 Block=52908x1 Type=Byte, ColorInterp=Blue
------END file format message--------------
--__--__--
winGRASS at grass.itc.it
End of winGRASS Digest
More information about the grass-windows mailing list
