[winGRASS] data format (Linux - Windows)
Jaro Hofierka hofierka at geomodel.sk
Sun Jan 22 02:15:33 EST 2006
OK, then try to export/import data using ascii data format (e.g.
r.out.ascii/r.in.ascii, etc.)
Jaro
Lubica Cverckova wrote:
> Hi,
> Thanks for respond. It is greatly appreciated. Anyway, if I open in Windows Grass a file developed and fully run on Linux Grass, all what it says is that it can't open the file because of bad file format. Any thoughts what it can cause?
> Lubica
>>-----P?vodn? spr?va-----
>>Od: Jaro Hofierka [mailto:hofierka at geomodel.sk]
>>Odoslan?: 21. janu?ra 2006 21:04
>>Komu: Lubica Cverckova
>>Predmet: Re: [winGRASS] data format (Linux - Windows)
>>Lubica,
>>Maybe it would be better if you could send us an error message you are
>>getting from Windows/cygwin GRASS while importing data, what kind of
>>commands have been used for what type of data (raster, vector), etc..
>>Jaro
>>>Hi,
>>>I have been working in school with GRASS on Linux machines. Now, I
>>>installed GRASS on Windows and I have been trying to work with the
>>>same data that I developed with GRASS on Linux. But it gives me an
>>>error that it is an unsupported format. Now, I need to have only data
>>>in .dm or .dmrc format, and I having problem to find some software
>>>that would convert data I have into that one. So, I wanted to import
>>>a binary file, and still I am having a problem, which I did not have
>>>once I worked with GRASS on Linux. Does anyone know about some kind
>>>of converter or sth. that could convert GRASS data developed on Linux
>>>into Windows GRASS? Any help will be appreciated. Thank you. Lubica
>>>Aktivujte si neobmedzenu mailovu schranku na www.pobox.sk!
>>>_______________________________________________ winGRASS mailing list
>>> winGRASS at grass.itc.it http://grass.itc.it/mailman/listinfo/wingrass
>>>__________ Informacia od NOD32 1.1365 (20060114) __________
>>>Tato sprava bola preverena antivirusovym systemom NOD32.
>>>http://www.eset.sk
> http://www.eset.sk
More information about the grass-windows mailing list
